Will 2010 Camaro SS Brake Rotors & Calipers fit on 98-02 Fbody??
Old 07-16-2010, 01:59 PM
1Ls1's Avatar
Exclamation Will 2010 Camaro SS Brake Rotors & Calipers fit on 98-02 Fbody??
i was wondering if 2010 camaro ss brake rotors and calipers will fit on 98-02 f-body?
Old 07-16-2010, 02:00 PM
cookba's Avatar
search. there is already a thread on this and its still active.
Old 07-16-2010, 02:49 PM
1Ls1's Avatar
what do i search cause i cant find it?????
Old 07-16-2010, 02:55 PM
jimmyducati's Avatar
i started the other thread,,, ive done a bit of research on it and it seems they will fit as they are the same calipers as the cts-v have with the exeption of using 14mm bolts so you will either have to drill the spindle or use a sleave on the caliper... using the zo6 14" rotor is a better idea though, same bolt pattern as an f-body and there would be no offset issues.
The following users liked this post:
Matt Miller (12-14-2023)
Old 07-16-2010, 03:19 PM
1Ls1's Avatar
well i already have all the 2010 camaro ss front and rear brakes complete. thats why im trying to use them
Old 07-17-2010, 11:04 AM
sweet! check the sticky in the brake and suspension section and follow the instructions posted there. its really simple, use 2 1mm washers (i would have stainless steel spacers made, seems it would be alittle more stable than washers) to backspace the calipers, or basicly center them over the rotor. The gen 5 camaro uses a slightly different bolt pattern, its only a few millimeters off but bottom line is its different. the C6 Z06 rotors are mad cheap and there are plenty of aftermarket replacements for them. Good luck on the install,,, lots of pictures and a write up noting any differences between the cts-v install and gen 5 install would be great.
Old 07-17-2010, 12:14 PM
1Ls1's Avatar
can i use the c6 zo6 rotors on stock 17" firehawk wheels?
Old 07-17-2010, 01:58 PM
98blackbirdta's Avatar
yes, but u will barley, i mean barely clear, like the thickness of a finger nail. i wouldn't recommend it.
Quick Reply: Will 2010 Camaro SS Brake Rotors & Calipers fit on 98-02 Fbody??
