Stable at high speeds
Is the assumption perfect pavement, or bumpy and rough, or both?
What, specifically feels unstable?
I have read the driveshaft needs an upgrade at really high speeds, like a carbon fiber one:
http://www.acpt.com/article4.html
Plan on contributing anything useful?
Mine is stable all the way to about 160 mph.. I had the car on the autobahn while I was stationed in Germany. I have all my suspension done minus the k-member, upper and lower control arms.. and i had 275's all the way around
Not really.
Too much effort asking the same old questions about current set-up, speeds you are encountering instability, what is the car actually doing and at what speed ...
Asking generic questions like "How do I go faster?" without any supporting data doesn't get any where.
But with an STB, you can at least leap tall buildings in a single bound ...
Not really.
Thanks to everyone that has contributed info I can actually use to fix/diagnose the issue.
I would assume some welded SFCs should help. Have you had your alignment checked, and ensured everything is snugged up/torqued right?
Have you considered a Watts Link? Strano mentions that running it allowed him to take a lot of previously necessary wheel spacer out too. That's how much lateral movement there is from the arc of a PHB. I am not certain how much this applies (if at all) in just straight lines, however. Maybe Strano can chime in too.
LS1TECH Sponsor
I'd start my checking the alignment and running a bit of toe-in on the front to make it track better than zero or toe-out.
But the aero on the car sucks. Anything you can do keep air out from under it, like a deep chin spoiler, etc helps. But you have to remember the cooling air all comes from underneath too, block it off and your car overheats....
I imagine what you are feeling is a sort of buffeting? That's air.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
