Aftermath of stock torque arm after 315 DRs
Well, I got my new C5 DD wheels with some Toyo 315 drag radials mounted last Thursday. That night, I took it out for a test. I did some dig launches on a dead street, only trying like 2.5k-3k rpm launch.. The next day driving around I notice a lot of loud clunking when I hit a bump. I thought my wheels/tires were hitting the bumpstops.. So I install some ARP wheel studs and 5/16" spacers (which I planned to do, anyhow).. I take it for another drive, and still a ton of loud clunking..
So today I look up under the car with the plan to tighten every bolt in the rear suspension that I see. and I find a busted torque arm... I never had these clunks until the first night with my 315's, so I guess it was it's time to go. I guess it's my time to go ahead and get a UMI tubular torque arm. Should I get an adjustable or not?
Pics:
Oh, and before anyone says it. I plan to have the rear-end rebuilt with a new pinion seal this year
Pics:
I think you should quick add another disclaimer about putting money into a 10 bolt, because you're going to get attacked for even bothering since you'll be running running 315 dr's with a nice torque arm lol
Also I think I'll do a stock length torque arm with the relocation bracket, any opposers?
That's pretty nasty looking!
A new UMI torque arm will take care of that As for the rear end, if you take it easy it shouldl survive for awhile. The wheel hop is one thing that kills them, try not to launch where the car will hop, if you feel it start to grab the clutch as quick as possible. Now of course wheel hop isn't the only cause and over powering it can destroy it as well.
If you have any questions please ask. Thanks!
Ryan
Ryan
I'm pretty sure from what I've read (and I'm not positive), that a short arm is actually better for powering out of corners too. It's just the brake issues that makes it not worth it for autox or road racing.
Anyone feel free to correct me
If your only "carving corners" around a hairpin turn on backroads but you like to put power down on launches, just get a damn short arm. Your not going to be doing any serious braking on the street.. so brake hop shouldn't be an issue. I'm assuming you like to drag your car with the 315 drag radials. Know your priorities.. I'm going to guess that putting that power down on a launch is more important to you than fixing brake hop when you mess around on the street where your not actually competiting with anyone else. Plus you'll be getting all that shock off your transmission.. do a search on cases where people bust their transmission tail shaft is it called??? You can do that with a relocation kit with the long arm as well.. but if you ask me the short arm is just a better choice for you.
on the other hand, I have road raced mine and I drive hard on the street. I have a badass brake setup and have NO brake hop any where else. Road racing, it performed flawlessly. On the street its great. That is the one part that got rid of my wheel hop. I've done some hard burnouts on the strip and had not a hint of wheel hop which is where I used to get it.
Location: Oklahoma City, OK/North Long Beach/Paramount, CA
thanks
I just bought a umi full length t/a with the relocation crossmember. After talking to Strano that's what he suggested. My car is a street car and I like to turn. You can adjust the instant center to help traction. He said if you use a tunnel mount three point sfc's r a must.
For short tunnel mounted torque arms UMI offers them and I posted a link below to all our torque arm set ups. We offer four short styles and the difference is what exhaust systems they are made for and whether you want a built in drive shaft loop. If you have any questions please ask and I will be glad to help.
UMI Torque Arms
Thanks!
Ryan
It's official, I'm going with stock length and relocation bracket. It sounds like the better setup for what I want, and less worries of exhaust clearances, which I highly think I will have exhaust clearance issues! I'll be ordering from UMI next week
Now, I see the relocation brackets have different adjustment points on it to mount the TA mount to it.. Will it come with instructions on where to mount it for pinion angle. Because, with an adjustable TA, and the relocation bracket, it looks like there will be two ways to adjust the pinion angle, who has experience with both these two and their experiences on the best way to adjust?
The best thing to do is once you get the items in your hands give us a call or e-mail and we can explain it a little better. It makes a lot more sense when you actually have the items in your hands.
If you need any help ordering or have any additional questions please ask.
Thank you, we appreciate the business and support
Ryan
same thing happened to me yesterday on stock tires lol
https://ls1tech.com/forums/general-m...mage-pics.html
