Grinding Noise on driver side rear wheel.
I went canyon carving this weekend and drove the car pretty hard for a good 10 minutes or so.
While it was a lot of fun, the end result was now I have a grinding noise every time i make a left turn. It appears that the grinding noise comes from the rear passenger side wheels, and only happens when the suspension in under load. If make a left turn really slow, everything is jolly. If i speed up a little bit or make a sharper left turn, it grinds.
I took the wheel off to inspect and could not find anything that has a scruff mark. My best guess is the parking brake is grinding against the rotor, or something in that area.
Anybody has experience the same problem before? I just want to see what everyone's opinions on this matter. If I could not pinpoint the problem, I'll just take it to a shop for them to analyze it.
Thanks!
Thanks!
could be a wheel bearing.? i am having the same issues but i think the noise is coming from the front passenger's side. does the noise change any when you: brake, speed up or slow down, press in the clutch, take it out of gear and coast, etc.
The noise only appears specifically when i make a rather sharp left turn which put the right rear suspension under load. When I brake, speed up or slow down, press in the clutch, take it out of gear and coast, everything is fine. I did not have the chance to take my rear brakes out as I am hoping that's the culprit, not a bend axle or anything or that sort.
Thanks.
LS1TECH Sponsor
Sounds like a tire or wheel rub to me.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
It sounds like that, except i do not see any wheel scruff mark of any sort, that's what bothers me. The thing is, i have to make a rather sharp left turn at around 40mph or more for the sound to exist.
I will lift the car up again this weekend and try to pinpoint the sound.
