safe to jack from differential?
it's probably best if you can put the jackstands under the rearend instead of the car actually. that way the rearend's not pulling down on the shocks and it's settled down like it would be if it was sitting on it's tires. that said, i've done it both ways plenty of times with no problems. and jacking from the rear is just fine.
hi,
the aforementioned are correct in their quote. however, use proper safety with jack stands and ramps. i also use 8x8x14 inch wooden blocks with 2x6x8 inch blocks on top. you can never be to0 safe.........double check everything and use caution to avoid injury....safety....safety....safety....
have a blessed day...........jim
