Rotor and Caliper Options
Do not want to grind or use spacers with aftermarket 15" diameter wheels.
Car is a 1998 Camaro.
Looking for Rotors and Caliper options (Front/Rear) that will work with after market 15" diameter rims.
Car will be driven on the street and need to retain the parking brake.
Wilwood, Strange, others?
1998 Sport Gold Hardtop
Thanks,
Mike
Thanks,
Mike
Mike,
Here is a link to the Wilwood site showing some brakes that will fit using 15" front wheels. The streetability of a non vented rotor depends on Your driving style.
http://www.wilwood.com/BrakeKits/Bra...Camaro&option=
The rear kits require a 17" wheel so I will continue looking for another possibility.
Carl
Carl
Mike,
Carl
Carl
Use the .81 thick rotor?
Does the .81 thick rotor come cross drilled/slotted?
Mike
Mike,
Carl
Carl
Searched and found this.
http://www.wilwood.com/BrakeKits/Bra...mno=140-7140-D
After the LS conversion I am going swap out the rear for a 9 inch Ford.
I already have the rear and Strange late model big bearing ends.
I can than narrow the rear 2 inches per side and used a 15 inch Street Lite rim with a 5.5 inch backspace.
The plus side I will still retain the parking brake since this build will be a street/strip car.
Car will not be a daily driver primary used for car cruise nights and drag strip.
Mike
Aerospace offers some good brake kits for around 530 but dont retain the parking brake and will clear any wheel with at least a 13.150 ID. Just to give you some more options
