Sway bar hitting 9inch rear end. Advice?
So I notice going over bumps that I hear some small bangs from back, it seems like my sway bar is hitting my 9inch rear end. There is very little clearance right where the torque arm mount bolts go into. Anybody have any hints or ideas to help?
I did a quick search and couldn't find anybody having any issues.
I'm going to piggyback on this thread. Mine does the same except it is always contacting the Moser. What's the best way to add clearance? Could I grind a bit off the tube? It looks like there would not be much, if any ay all, structural integrity loss
Sorry for the delay. Here's the link I mentioned. The U-bolts are long enough to shim the bar down a bit if you need to.
http://www.umiperformance.com/catalo...roducts_id=322
LS1Tech Premium Sponsor
You can definitely grind it down without any issue. Unfortunately it is a somewhat common deal due to where they weld the mounting points for the torque arm bracket. 5 minutes with a grinder and the problem will be fixed.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
they are UMI just as in the link. bran new never used. let me know if you need them.
Are these brackets the cheapest way to add a rear sway to a moser?
Or should I get ahold of moser and get the brackets from them since it was originally an option for my 9inch?
I don't mind welding on brackets if it's cheaper. I just want to be able to run big bars and not hit my bmr torque arm or drag the bar on the ground.
