LCA relocation bracket ?
LS1Tech Premium Sponsor
If you are using bolt-in relocation brackets you can use the non-adjustable lower control arms without any issues. If you are using weld-in relocation brackets you can use non-adjustable lower control arms but the relocation brackets have to be welded in perfectly and that is pretty hard to accomplish. I personally always recommend that our customers use adjustable lower control arms if they are going to be using the weld-in relocation brackets, this will for any adjustments that need to be made to allow the wheel to be centered in the wheel well.
Kyle
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
