UMI drive shaft loop
Old 03-20-2012, 03:34 PM
stetay2233's Avatar
Default UMI drive shaft loop
I just got my 3 point subframe connectors and safety loop installed last week.
And I noticed that the loop has take a good deal of grpund clearance. Does anybody else have this problem? I was planning on getting strand springs and they drop 1.2" so now I'm kind of worried.
Old 03-20-2012, 03:35 PM
stetay2233's Avatar
Strano*
Old 03-20-2012, 10:00 PM
UMI Sales's Avatar
Which loop do you have?
http://www.umiperformance.com/catalo...ex&cPath=7_183
As you can see, one is flat and one helps exhaust clear...
Ramey
Old 03-21-2012, 04:04 PM
stetay2233's Avatar
i have the long tube header one since i am running pacesetter long tubes and their 3" ORY pipe to a hooker 3" catback.
don't tell me i ordered the wrong one?
Old 03-21-2012, 08:06 PM
UMI Sales's Avatar
Did you order the 2025 with the kink?
ramey
Old 03-22-2012, 08:00 AM
UMI Performance's Avatar
Both our loops might work, the 2025 has more clearance built in for lower hanging exhaust systems. The downfall is there is some reduced ground clearance. #2032 sits up tighter but may not clear all y-pipes.
Old 03-22-2012, 01:57 PM
stetay2233's Avatar
i have the 2025. i got that because i saw it was for the pacesetter system. they said they had to move my exhaust around to make it fit.
have you seen anyone with this run lowering springs? or on a aftermarket shock spring car?
Old 03-24-2012, 06:20 PM
stetay2233's Avatar
anybody else running this loop with strano springs?
Quick Reply: UMI drive shaft loop
