Hit pothole durning autocross now steering is bad.
Did a autocross even on an old go cart track and i hit a pothole or just a hard hit on a bump and now my steering is messed up , the right front is toed in and the camber is top if tire in bottom out . I drove it home no faster than 40 and its way the hell off , i dont see anything wrong with it . Front end is up and rims are off and everything looks good .
Steering wheel is way off , how do i found out what the hell is wrong with it? Im lost .Everyting looks fine, nothing bent or loose .
Just take it in and get it aligned at a reputable shop. If nothing is bent, just knocked out of whack, they'll be able to put it back where it belongs no problem. If something is bent they'll be able to tell you that too. A harder hit on a pothole or something at the right angle can shift stuff.
Boy I hope it's just out of alignment and that's it. But the steering feels funny. It's like it's easy to steer. And when you get to the point I noticed turning left going in the garage it got to a point and then was easier to turn.
LS1Tech Premium Sponsor
Potholes can be scary business for sure. Holding an autocross on a course with potholes was not too bright! haha
Did the front of the car sustain the brunt of the hit and was it centralized on one side? You can whack your car out of alignment, albeit uncommon. Usually something will bend, so make sure you inspect every inch of the front suspension, a-arms, shocks, balljoints, and tie rods. I would be surprised something wasn't a little tweaked.
- Kevin
- Kevin
Not sure if an actual pothole but a non smooth course. It's an old go kart track. Thanks everyone for the info. Everything looks great I'm gonna set up an appointment for an alignment and hopefully its just that
I had something similar happen before(not auto x though) I hit a lip while the front tires were slipping and messed my toe alignment up. The RF pointed in slightly when the wheel was straight. The steering felt light as well. I adjusted the toe out myself slightly to get home from work (30minute drive) and I was taking a left turn and the outer tie rod came out of the socket. Luckily I wasnt going faster than 10 mph bc that RF tire immediately pointed all the way inward. One of my buddies that was catching a ride had to kick the back of the tire the whole time to keep it straight so i could get out of the intersection lol
Update to the situation
Just needed an alignment , the bolt on the a arm had moved and changed some things up .
Now experts answer me this , how does this one bolt hold the alignment , this car weights thousands of pounds and one bolt hold the alignment strong , how is that possible .
Only two bolts hold the engine in place while it's churning out 300+ ft lbs of twist. They seem to manage alright though.
