Recommend me a PHB
Recommend me a PHB
I plan on ordering Koni's and BMR springs in the next week. Theyll lower the car 1.25". I have 17x11 Fikse on the back of my car. What panhard bar would work well with my setup? Will I have to roll the fenders? I didnt bother searching, Im looking for some input from guys who either run those springs or 17x11 Fikse. Any help is greatly appreciated. Thanks in advance.
-Matt
-Matt
You will probably have to roll your fenders with your 315 and x11. My buddy just put in BMR/bilstein with 315 and x10.5 wheels and had to roll his. As far as PHB I would just buy a single adjustable from founders. I have a Spohn single adj on mine but that's because I got them used with LCA's.
What tires are you running? Some 11's are more equal than others. I run 17x11 (GS-DS3 tires), am lowered the same amount, and used to run a UMI PHB. I rolled my fenders, and BFH'd. Usually end up doing at least one of those two things. How much rubbing you notice depends on the aggressiveness of your driving also, hard cornering reveals the rubbing loudly.
Yeah, really all depends. What is the offset on the wheels? If this offset is correct you may be able to get away with just some BFH'ing.
As far as which PHB, i put exclusively UMI and strano products on my car. I would reccomend a UMI adjustable for you. However, BMR also makes good products.
LS1Tech Premium Sponsor
I would recommend using our BMR adjustable panhard rod with poly bushings (PHR002), it will do everything you need it to and it is double adjustable so you can adjust it with it installed on the car.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Anyone know the difference between poly bushings and rod/rod style?
Rod ends are often know for being very harsh and are known for not lasting as long as other options. They are good for a dedicated race vehicle or a weekend cruiser. For a daily though, I would reccomend roto joints. They are a happy medium between the poly and rod ends. Still let the suspension articulate well, while not being overly harsh as well as a longer life span than rod ends. UMI makes these, and they are what I use on my vehicle.
Poly is ideal for a drag setup. However, if handling is a priority, a rod end or roto joint is your best best. Poly does not let the suspension articulate well, while rod/roto allows it to articulate freely.
The PHB controls lateral location of the differential housing in relation to the car. It's one of the few places where we can use a rod end with minimal NVH (Noise, Vibration and Harshness). As we move from rubber to poly, poly to Roto, Roto to rod end, the lateral movement keeps decreasing which in turn makes the car feel more stable.
The difference between feel in rubber vs poly is pretty high, keeping in mind it's hard to measure via the seat of the pants technology. The difference between poly and Roto/Rod end is comparatively less.
Double adjustable is nice as you can set the PHB length without removing the main attachment bolts.
Double adjustable, double rod end is pretty sweet for sure but even a basic poly bushing model is a nice upgrade.
http://www.umiperformance.com/catalo...Path=7_138_106
ramey
ramey
Whatever brand you buy I would recommend an on car adjustable model, it makes the adjustment of it alot easier. As far as brands, I have had UMI and spohn (current PHB), but I just recently bought a few items (no PHB) from founders performance, and there parts are quality pieces, dont be fooled by the low price.
If I could do it all over again, I'd go single adjustable. I purchased an Edelbrock 5222 double adjustable PHB when I dropped my car and had problems with it coming loose as I drove around even though I tightened the bolts tight. I straightened it out and put some blue Loctite on the bolts and it seems to be hanging in there. I still don't like knowing that it has a possibility of coming loose on car but that's just me.
You can draw this out with a bow compass. Put the spike on the black dot in the red circle, and the pencil end on the black dot in the green circle, and scribe the arc.
With the limited travel available it shouldn't be much twisting in the PHB, but it is there.
