What else should I replace while installing new shocks/springs?
I'm installing my new konis and bmr springs in a few weeks thanks to the great deal by bmr Now I'm just wondering what else I should replace while I'm already under the car?
My car is a 2000 WS6 and has about 100k miles on it. Are there any parts that usually wear out around this time or in the near future? It's a daily driver and autocrosser.
Thanks in advance.
Thanks in advance.
yea you might want to pick up some upper strut mounts, as most of the cars that i have seen have been all rusted up under there. mine were all kinds of F'ed up under there, i had to sand blast them, and re-paint mine. they were pretty stuck to the body as well. by upper strut mount, i mean the big 2-piece metal horseshoe looking thing that the balljoint is in.
I'm doing the same instal. I went ahead and got all three pieces so I could put the new on and not have to take apart the old ones. Both of my outer tie rods and upper ball joints were wore out, so they are getting replaced.
The milage really doesn't matter from what I have seen on here. People have posted pictures of their SHOCK mounts on a 20k mile car and they still looked like hell. You can salvage them if you take your time and are careful, an air chisel will help alot.
I wouldnt worry about replacing these parts unless they are wore. To check them set your jack under the a arm and lift the wheel off the ground. then grab a hold of the wheel and shake it. If you have any movement then somthing is probaly wore out.
My car has 150k on it and still had all the original parts. My tie rod ends were really wore out. The ball joints werent wore themselves but the boots were cracked and letting the grease out so I just replaced them.
