Keeping torque arm bushing in place. Help.
I've got an UMI torque are relocation cross member. Stock torque arm. I'm having a hell of a time keeping the bushing in place. Actually lost it while the car was on the trailer on the way home from my last event. Any tricks to keep it in place?
LS1Tech Premium Sponsor
So you guys are having an actual issue with the bushing sliding out of clamp with the torque arm relocation crossmember? Are you guys using the aluminum spacer that comes with our torque arm relocation crossmembers to take up some of the excessive space? Let me know because this should definitely not be happening.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
So you guys are having an actual issue with the bushing sliding out of clamp with the torque arm relocation crossmember? Are you guys using the aluminum spacer that comes with our torque arm relocation cross members to take up some of the excessive space? Let me know because this should definitely not be happening.
As far as the spacer, I'm not sure if it was installed originally or not, I remember seeing it at one time since you've reminded me. I'll see if I can find it around here. I assume it was desingned to lock the bushing in somehow?
Thanks for the replies!
Yes. I've lost 2 already. I put the cross member on but could only adjust it to one setting because of my exhaust routing. The first time it pushed out was after 1500 miles of installation but I had a pretty good valve cover gasket leak so I blames it on over sprayed oil lubricating it. I fixed that and replaced the bushing and After about 2000 miles it fell out.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
I don't have the aluminum spacer. Also, I don't have the energy suspension bushing. I had a prothane poly mount.
When I looked up the energy suspension mount, I see how it has a lip to keep it from moving.
As far as the spacer, how thick was it? I could cut one on my CNC machine unless it'd be easier to grabbing from you guys.
Thanks Kevin
Thanks Kevin
Thanks Kevin
Thanks Kevin
If you don't have that aluminum spacer than that could definitely be your problem, that little spacer takes up space so the torque arm bushing can't move around. If the Prothane bushing doesn't have that lip on the outside of the bushing I would swap over to the Energy Suspension torque arm bushing because that lip will also keep it in place.
That aluminum spacer is 1/8" thick and is a super simple design so it is something you could definitely make and if not give us a call and we can get you taken care of.
Kyle
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
