Kw Coilover VS. Koni 4/4 w/ strano springs.
LS1TECH Sponsor
KW's are really nice. They are, in fact I currently have a set on my new daily driver Scion FR-S.
KW's cost more, but are double adjustable. Yes, Koni also make double adjustable shocks too, and you could get those and my springs for still a bit less than the KW's). But the KW's offer you the ride height adjustment, and if you should wish to change them, the ability to swap in different rate race springs to tune things. The entire KW kit has a lifetime warranty, and the bodies are stainless steel (and if you read the thread about the guy that wasn't happy about rust on his steel shocks, that might matter to you).
If you are going with a bigger rear axle, having shocks that allow you to adjust compression damping is a big help, Koni SA's don't have that ability you would need DA's to do that.
Both work extremely well, I think the Koni/Strano setup is a better value since they aren't as "bling" with the stainless bodies or height adjustment. But you may want some of those options.
__________________
LS1TECH Sponsor
It's a 2 liter with a compression ratio of 12.5:1... so yeah, it requires premium.
__________________
