Corvette calipers
LS1Tech Premium Sponsor
If your car has Corvette calipers, a previous owner had them put on. The F-bodies didn't come with these calipers from the factory or the larger rotors they bite on to.
Be happy! You have slightly increased braking torque thanks to increased leverage and slightly larger surface area for friction and thermal distribution.
Your saying that they are a direct bolt on if you use stock rotors?You don't need the corvette mounting brackets unless use the c5 rotors? How much of an improvement in stopping power do you get if you those calipers?
