what shocks to get ?
I added the eibach pro lowering springs on my 2000 ss and replaced the front shocks with cheap autozone ones until i had the money for good ones but these seem to be blowing out so im just goin to have to buy the shocks now ,
I need to know what shock i can get that will not blow out with the lowering spinga installed , also dont want to break the bank either
I don't understand why people on this forum will dump $10k on a motor then consider a nice set of shocks for <$2k baller status. I mean what's the point in having 700hp with stock shocks. You might as well buy a jet boat since they'll drive about the same. Obviously $500 for some bilsteins is extremely conservative because autozone shocks run almost the same cost, but consider that you're going to most likely want a better shock down the road. Save the money and buy something nice that's not going to leave you wanting more.
I just put bilsteins on last and love them. its not about baller status. You have a comfy ride or you dont. End of story. I got rid of my stock decarbons with 90k on them becuase I hated the lowering kit. pain in the ***. so stock springs and bilsteins are great. But if your all for the springs you want to balance the shocks to ride nice so your not hating every bump. Or qa1 adjustables if you got money to throw around like that lol
LS1Tech Premium Sponsor
Eibach springs will continue to drop a little bit lower. They move like a glacier, fractions of an inch a year. LOL That being said, Bilstein shocks may not be your best option for a spring that's going to drop bellow 1.5 inches. Koni shocks can handle the punishment better in that scenario, so I would suggest them to you.
- Kevin
- Kevin
Lowered? Better get Koni.
But I've got two rear SLP Bilstiens for sale still in good shape, with a full Eibach prokit for sale if anyone's interested.
LS1TECH Sponsor
Dude, you called the wrong place. I've got 3 sets in stock, could ship them Monday (had it seen this earlier today I could have shipped them today).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
Which shocks? Depends on how well/how long you expect them to work...
Bilstein's will do pretty decent for a while, but you will see them become less and less well damped as the miles go on. The Eibach's aren't' super stiff springs, and when new the Bisltein's can damp them reasonably well. However, the Bilsteins are working pretty hard to do it, so as they miles go on and the shocks wear, at some point they won't be as good at it anymore. Add to that the Eibach's tend to put you in harder contact with the rear bumstops (all springs will do it some, Eibach's just don't have a good spring rate vs. height ratio), and the Bilstein's aren't great at dealing with how the car comes off the stops.
FWIW, they aren't $500 a set, they are under $400 a set.
Koni's rock. Have for a long time, which is why I've been selling (and using) them for so long.... 15 years+. I run them on my cars (though I have KW's on my FR-S) I daily driver. I had Koni's on the Camaros and Mustangs I won all my championships with, and used Konis when I was developing my springs. I have Koni's on my Corvette.
Are they cheap? No. But with the sale you can get into a set for a little over $730. Consider when they are not on sale they are about $150 more than what they currently are selling for. That makes them a better value now relative to other shocks, aside from the fact they are much better for the best control of the car (even with stock springs).
__________________
^ And didn't Koni rumor that they wouldn't be doing this sale again? We're lucky they did it this time.
OP, it's only about once a year, so I seriously wouldn't wait on this or the full price for a set of Koni's is going to shock you (no pun intended) and you may end up cheaping out for something you won't be happy with in the long run.
Listen to Strano.
Listen to Strano.
