BMR + Bilstein HD's
Old 05-23-2013, 03:21 PM
Gluemaker's Avatar
Default BMR + Bilstein HD's
First off big ups to BMR, Bilstein, and UMI. Also a huge thanks to Mike @ Ws6store for getting me all of this. I would recommend this setup to anyone looking for a good bang for buck. Springs gave me a good low look and the shocks keep everything in control. It is NOT harsh or bouncy. Rides about like a C5 Z06. I do have longtubes and TSP trueduals. Being aware of road obstacles and I don't scrape (I'm 6'2" 232lbs). Found that a passenger over 150 and it starts to hit normal bumps in the road. For anyone confused by installing the lower spring perch on the Bilsteins, a rubber mallet will get it off the stockers and it will just slide on the new stuff. I don't have many pics as of right now but I'll update when I get some.
Total Mod list for those interested:
BMR Springs
Bilstein HD's all the way around
C5 Deep Dished Rims 17x9.5 front 18x10.5 rear with 315's
UMI Adj. Panhard Rod
UMI LCA's
UMI LCA relocation brackets
Fenders are Rolled and I did BFM mod for rear
TSP Trueduals
Only before shot:
After
Old 05-23-2013, 03:27 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
The car looks goods! We appreciate you choosing BMR for your lowering springs and if there is anything else we can help you out with in the future let us know.
Kyle
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 05-23-2013, 03:30 PM
Coppertone's Avatar
I have konis with stock brings right now (lower perch up front, heater hose in the back). I have BMR springs on the shelf and the only reason I'm not installing them is because of ground clearance.
Someone make a tight tucking y-pipe please! lol
Old 05-23-2013, 03:38 PM
Gluemaker's Avatar
Do you daily the car? The springs do drop it a good bit. I'm getting by with true duals. However, I drive a pickup truck everyday.
Old 05-23-2013, 06:10 PM
Coppertone's Avatar
No, it's not a daily. Do you have a measurement of the lowest point of your exhaust to the ground?
I'm also about 230lbs
Old 05-23-2013, 06:39 PM
Furious1's Avatar
Thats my combo and I daily, no problems.
Old 05-23-2013, 08:20 PM
Gluemaker's Avatar
I don't as of now. I lowered the car, and did a bolt check the next morning. Cleared South Carolina in it to go to the beach, and then came home. Only scraped twice on some very bad rail road crossings. If I had to take a visual guess its a hair under an inch from the turn downs to the ground. However it only scrapes the actual mufflers. When they were installed I let some friends do it while I was working. I believe they could have done a better job at placement of them. Shocks are what save it. I can imagine (having driven friend's cars with springs and budget shocks), that a stock or parts store shock wouldnt rebound well enough to save the scrape. My buddy has a prokit on his SS and it looks a tad lower than mine. He has longtubes with a hooker y and catback. That car NEVER scrapes unless he is just being stupid over speed bumps and going from pavement to dirt. I can go out and get a measurement tomorrow though. Pretty much if you run full exhaust, you will be ok if you keep an open mind to road conditions and environment. Also, I've taken it down the track with this setup and had 0 issues with scraping, sparks, rubbing, ect.
Old 05-23-2013, 08:29 PM
Coppertone's Avatar
Under an inch? wow. I think I'll be about 2.5 inches if I put the BMR springs on. That's good to know that it doesn't scrape that much though. I'm running LT's, catted-y, and catback.
Old 05-23-2013, 08:49 PM
Gluemaker's Avatar
Yeah, people lie about trueduals and how they have clearance and blah blah blah. There is more adjustment room to get them up to about 1.5 inches, but the torque arm will pretty much hit them every time the suspension is on a light load. So its a sacrifice thing. However, I lowered the car with no intentions on keeping the TD's. They get me by for now but my current build won't have need for headers or Xpipe.
Old 05-26-2013, 12:58 AM
The Guz's Avatar
That's a nice drop with the BMR springs.
Old 05-26-2013, 01:47 AM
Blackbird-WS6's Avatar
Can you post the height of each fender from the center to the ground?? Thanks
Old 05-26-2013, 11:29 AM
apicia's Avatar
Why did you decide to go with HDs instead of the SLP Bilsteins? I am still trying to figure out cost/benefit of shocks and which to go with.
Old 05-26-2013, 05:00 PM
Spartan7's Avatar
They're the same shock, pick the cheaper one.
I'm running the same setup, ground clearance is actually pretty good with my Kooks. The exhaust will barely touch over speed bumps if I go too quick.
Old 05-28-2013, 11:18 AM
Gluemaker's Avatar
This. They were listed as HD's and were cheaper but they are the same.
Old 05-28-2013, 11:22 AM
Gluemaker's Avatar
Both Fronts are 25 3/4 inches
Both rears are right at 26 1/2.
Old 05-28-2013, 01:28 PM
My rears are at 27+ wonder if thats bc of my 9inch?!
Old 06-02-2013, 10:20 AM
supersick99z's Avatar
HD's are lifetime warranty I believe and the SLP's are only 1 year
Old 06-02-2013, 11:07 AM
Coppertone's Avatar
How's the ride quality? My Koni's are very harsh and I'm considering moving to Bilsteins.
Old 06-02-2013, 12:26 PM
Nothing harsh about this combo. Iv had used this combo and it was very nice for a DD car.
Old 06-02-2013, 01:09 PM
Coppertone's Avatar
Right now with Koni's on the lower perch with stock springs I am feeling every pebble, bump, seam, and bump on the roads.... (Brand new Michelin Pilot Super Sport tires)
I can't stand it. I'm disgusted every time I drive the car.
Quick Reply: BMR + Bilstein HD's
