spring and shock ride height question.
Hi all, i have a 2002 firebird (v6). Its a daily driver for work and back. As it sits now the front end height is 26.5" wheel well to ground . The rear is where theres a problem, 29" on driver side and 28.5" on passenger side. I'm not sure if the car was lowered or not. If so how can i tell how it was done ? kit , cut springs , etc. I also need to look into the rear height difference. maybe just a blown out shock ? Any help and advice would be great . thanks in advance .
Hi, I've just completed a total suspension upgrade and hopefully this helps:
I've heard that a slight difference in spring height on our aging cars is common. So the half inch diff in height probably means its time for upgrades.
It sounds like the front end has been dropped. We put on Vogtland lowering springs and I'm just 1/4" lower than your front end. I found a pic of my stocker front struts, spring, upper and lower A Arms. Stock struts are DeCarbons, the stock A arms are not tubular but are a bent steel, the stock springs are dark ugly color. You can see the number of coils and compare to yours to see if stocks were cut.
Most aftermarket springs, even the ones on Ebay are colored. Just for Example; Stranos are white, Vogtlands are purple, some ebay ones are bright green and such.
Sounds like your rear height is stock or maybe just not a good set of matched springs. Sorry I can't find a pic of my rear springs but they are bigger coils and will be same dark ugly color with maybe (if your lucky to identify) a GM part tag hanging or rolled on a coil. The stocker springs are also DeCarbons.
Hope this helps.
Hope this helps.
Thanks for the quick reply. I have been busy all day. I was able to peak threw the rims and see the front shocks. There delphi M46 (?) , orange colored. The springs are some ugly black ones . On the rears are the same orange shocks, i wasn't able to get a number off them. The springs had a tag that is probably a GM part number . 10305134. The wheels i have on it may also be contributing to some problems, i'm not sure. There 245/35zr20 95wxl. They came on the car when i bought it for my wife. I do have the original rims and tires also. They were tossed in with it. Well thanks again for the info.
Sounds like the springs are stock, maybe the fronts have collapsed. since Delphi owns DeCarbon, they are probably stockers or an aftermarket equivalent. no problem, I get most of my info on these threads.
Sorry its taken me awhile to get back on . I really appreciate you taking the time out to help me. I am trying to post some picks i took today while i was changing out the oil. I would like to upgrade the whole package. Shocks ,springs, bushings,etc. I will be reading up on what brands are the best for comfort on a daily driver . I'm sure if the tires will be a problem down the road. My wife really likes them. But i have the stock ones if i need em . Well i should be getting some picks here shortly . Just to confirm there stock and show her off
Well there she is. She needs quite a bit of work , not a bad start tho. I been reading about the Bilsteins that Sam Strano sells. I will look into that kit with the springs and all tomorrow . Or Tokiko's if the Bilsteins are out of my price range. Who knows maybe i can find a used set for sale on one of the forums that someone upgraded from to something better. Well thanks again and any advice from anyone is always welcomed . Night.
Thanks for the response guys . Yep on the passenger side being lower . Its just a tad over half an inch lower. It's the side that scrapes and hits on bumps way more than the other. I plan on replacing the shocks and springs soon . That can only help. It may also be in part because of the tires(245/35r20). I may have to put the stock ones back on if these are to big after i install the new suspension kit . I still have a some more researching to do as to what kit to buy. It's just a daily driver for my wife so comfort is also a concern.
