Broken Stud, Can't Remove Caliper Bolts
Old 01-21-2014, 06:58 PM
VelociRaptor's Avatar
Default Broken Stud, Can't Remove Caliper Bolts
Hi everyone,
I've been reading the various posts regarding the caliper system on LS1 tech and though informative, haven't helped my issue.
This question is for a 02 base firebird. I have a broken lug stud on my driver's rear wheel and want to replace it, however, I'm having a hard time removing the caliper bracket bolts. From reading the posts, these have a much higher torque than the caliper bolts holding the pads. I can't even loosen the bracket bolts and am reluctant to attempt it for fear of stripping them. I'm using a 3/8 ratchet by the way.
What is the proper way to 1.remove these bolts and 2. put them back on and tighten them safely?
Old 01-21-2014, 07:48 PM
07bluelbz's Avatar
I used my air Impact on them.
Old 01-21-2014, 07:51 PM
FirstYrLS1Z's Avatar
impact or long box wrench with pipe slipped on for leverage.
Old 01-21-2014, 07:55 PM
07bluelbz's Avatar
Actually now that I think about it I was able to do the rear with a 1/2 inch ratchet. I had to slide under the fender and sit on the ground to get enough leverage though.
Old 01-21-2014, 08:00 PM
RJDio's Avatar
I broke my favorite ratchet on the rear right caliper bracket, using a long **** pipe from home depot for leverage. I could not get it off, so I took it to my buddies 1 stall shop and he put it on lift and got it out with an impact. Paid him $20 and we were both happy
Old 01-21-2014, 08:32 PM
1981TA's Avatar
Breaker bar + small hammer + floor jack worked for me. Put a decent amount of pressure on the bar with the floor jack and tap the socket lightly with the hammer.
Old 01-21-2014, 10:44 PM
SparkyJJO's Avatar
You need a 1/2" ratchet, minimum IMO. 3/8" just isn't going to be big enough to break them free.
I usually use my breaker bar or my long handle 1/2" ratchet just because it is even easier that way. They are tough bolts, odds of breaking them are pretty slim as long as you use the right socket size.
Old 01-21-2014, 11:04 PM
jsteele90's Avatar
1/2 inch is what you need. I use my Dewalt impact but with a 1/2 ratchet and some man juice you will get it off no problem. maybe let it sit for a hour with some pb blaster
Old 01-22-2014, 10:16 AM
Save the manuals!
wssix99's Avatar
+1. The bolt has a lot of torque on it for a 3/8" tool, alone.
Old 01-23-2014, 01:11 AM
Thank you everyone for the excellent input.
Old 01-23-2014, 11:57 AM
Midnight02's Avatar
Originally Posted by VelociRaptor
Hi everyone,
Ran into this over the weekend and mine came off with ease once I switched from a 3/8" to a 1/2" drive ratchet.
Old 01-24-2014, 09:27 AM
spy2520's Avatar
long handle 1/2" ratchet. I put that **** on everything.
Quick Reply: Broken Stud, Can't Remove Caliper Bolts
