Rhythmic Thumping Sound starts at 20 mph along with shaking??
I have a noticed a slight rhythmic thumping sound that speeds up and slows down with the speed of the car that sounds similar to a flat tire, but all the tire pressures are fine. Has anyone experienced this or know what could be causing it? Could be wheel bearings??? I can feel it through floor but the passenger cant on their side. Thumping starts around 20mph and the faster i go the faster the thump and the wheel shake
boola1341 Had the tires put on about 2 weeks ago and got them rotated and balanced again but problem still there.
U joints was replaced but problem still there. Lug nuts checked but problem still there. After tires balanced and rotated problem still there. Still feel the slight thumping on driver side but not passenger.
Update.....ok so I put my stock wheels back on and drove it a couple miles. Guess what,problem still there. So as I was putting the after market wheels back on I shooked the wheel and it had all sorts of play on the driver side. Passenger side not as much. It has to be the wheel bearing. So I ordered pair of wheel bearing assembly from company called Detroit axle which is located in Michigan makes parts in USA. It also comes with a year warranty
