Darty handling: where to begin?
My fairly new-to-me SS has 77k on the clock. It handles a bit darty at times, and I can tell if it's normal or not:
When coming up to roads with humps, it likes to track like its on rails... Unless you're breaking, then it gets out of sorts.
I attributed it all at first to lower-profile wheels and wide tires, but now I'm wondering if there's more to it... My daily driver and my wife's car don't track like the camaro, and those have similar tire and wheel setups (width/profile).
Since this is a second hand car, it's impossible to know if it's a trait of the car or something more. I know the tires are old, and new ones are on the way, but in the meantime are there ways I can test for weakness in the components?
You may want to get an alignment, and verify the specs they use if the Camaro is lowered (lots of discussion on here of what you should target).
I would say my TA has always been a bit jumpy when braking, ever since brand new. But it has always had good handling under driving. It was starting to tramline a bit recently and follow road grooves, but new tires and alignment cured that right up.
I guess I'll have to find an alignment shop around here to take a look after I install the new wheels/tires.
I was getting worried: reading some other threads it seems control arm bushings are an issue, especially with age.... It didn't seem like shocks either, but I didn't want to spend $ on an alignment, only to have to pay for another if I need to replace suspension components.
My first Fbody I spun out badly a couple of times, and have talked to a few that did same thing. If you take a turn too fast it feels grippy and then the rear will whip around fast and when you steer into it, will come around other side too. I've upgraded my suspension except for K member and upper panhard bar, and I drive it in straight lines. but be careful when cornering fast
That's what I'm afraid of. I'll admit I'm new to the sports car world, so I'm not the most experienced driver (I've been in SUVs and trucks for years), when it comes to driving sideways....
I'm just an on-ramp racer at this point, so any crash would be guardrails, and that wouldn't be good.
I'm confident at the speeds I drive Id be able to correct (knock on wood), but if I'm dealing with rotted bushings, etc, I doubt anybody could recover.
Again, I'm at stock height right now, so the geometry is all appropriate, outside of any potential alignment issues...
the beautiful thing about these cars is that there are TONS of suspension upgrades. I probably used all the vendors, shopped for a long time buying each component after researching, used dealer codes for discounts and pricing and put together a nice build kit. i upgraded to the heavy solid ST Sway bars, I also lowered with Vogtland springs, bought a reconditioned rack and pinion, and used Moog outers, and I gotta say this thing drives great!
OP I would check all the bushings and the alignment first and go from there.
