Planning a performance suspension overhaul - Need help!
My Primary goal is to build a hot street car. She will probably never see the race track; and if she does, it will be maybe once or twice ever. I just want the car to handle exceptionally well on the street. I already have Strano springs and koni adjustables, so I'm looking to add to that. When I did my spring/shock install, I noticed a lot of the bushings weren't in the greatest shape and the ball joints need attention, so here is what I'm thinking about doing:
UMI Upper and Lower non-adjustable A-arms
Moog upper ball joints
UMI Sway Bars
UMI adjustable PHB
UMI non-adjustable rear LCA's
UMI adjustable torque arm (not sure which model to get..)
Bolt-on subframe connectors (not sure here either)
New rear bump stops
18x9.5 wheels w/ 275/35/18 tires
The main reason I want the adjustable PBH and TA is because I've read that they are needed after lowering the car, to position the rear axle correctly. My concern about this is that I might not be able to get them adjusted properly, or do frequent adjustments if they go out of adjustment. I don't have any good performance shops in my area that could help me with this. Do these parts come with installation and adjustment instructions?
Based on my goals, could you recommend anything else I should look at? Or is there anything on my list that might be overkill for my application? Do I really need an adjustable PHB and TA if I'm not racing?
Thanks for any help you can throw my way!
UMI Sway Bars
UMI adjustable PHB
New rear bump stops
LS1Tech Premium Sponsor
If you were interested in BMR parts we would be more than happy to throw together a custom package for you that would take care of all your suspension needs without breaking the bank.
We definitely recommend using a adjustable torque arm and panhard bar on a lowered vehicle. The adjustable torque arm will allow you to get the pinion angle back where it needs to be and the panhard bar will allow you to center the rear end up underneath the car. Once you adjust these two parts initially you shouldn't need to do it again unless you change the ride height of the vehicle.
You have everything covered pretty well with your parts list. I would definitely recommend using a adjustable torque arm and panhard bar since your car is lowered.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
UMI Sway Bars
UMI adjustable PHB
New rear bump stops
UMI Sway Bars
UMI adjustable PHB
New rear bump stops
While an aftermarket torque arm is certainly not necessary for a good handling setup, if you choose to get one get a full length one, not the short one (they can cause brake hop). The adjustable PHB will center the rear end, another thing that is not needed, but your rear should be off center after lowering which can cause passenger side wheel/tire to rub the inner fender.
The PHB and torque arm are extremely easy to install and adjust, do not take the car to a mechanic to do this, it will be a waste of money and they will likely screw things up.
Also for best handling use 17" wheels. 18s are not bad but guys are running faster with 17s back to back (lighter wheel all else equal). They will ride better as well.
A few more questions--
To adjust the PBH and TA, does the suspension have to be loaded? IE not on jack stands?
It seems like all suspension components have rod ends or poly bushings.. I don't see any that come with rubber bushings... I always thought poly bushings were best for a street car?
I'm not dead-set on getting UMI components, I'm open to suggestions.
I'm definitely glad I posted this now! I had no idea about rubber bushings being favorable. Do these parts usually come with installation and adjustment instructions? I'm positive I could install them with no instructions, but I just want to play it safe. This is the first 3 link suspension car I have worked on.
We can build a custom package for whatever parts you decide you need.
You'll get a ton of opinions on here from many different people. I'm happy to answer any questions you may have.
UMI is your choice for ultra premium Made-In-USA of US materials suspension products.
later
ramey
Good morning.
later
ramey
later
ramey
We have rubber bushings for some of our parts. The majority of are parts are sold with polyurethane bushings. It really just comes down to what your plans and goals are with the car to what will style of part will be optimal for you. Since you are mainly concerned with handling I would recommend either rod ended parts or rubber bushings because you will not see the bind with them like you would with polyurethane bushings.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
What about your front lower a-arms? Is that something an alignment shop would adjust, or is that something I adjust once installed?
Sorry for all the questions, this is new to me!
1 Post
i strongly advise against rear poly/poly LCAs. made my ride on the street like hell... felt like my rear was slamming everytime I hit any bump.
I went with boxed stock LCAs and moog bushings... SO MUCH better
If you swapped out the front lower a-arms you would need to take your vehicle to an alignment shop and get the vehicle aligned.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
When you make adjustments it's always best to have the car on all fours just like you're going to be driving it. That allows you to see exactly what you're going to end up with. When tightening poly, it's also best to final tighten at actual ride height. With Roto-Joints or rod ends it doesn't matter due to how the product is designed.
ramey
Rubber bushings are going to be the softest and quietest while Roto-Joints are going to offer awesome performance and articulation. We have Roto-Joints in any of our cars destined for auto-x or road race environments.
ramey
ramey
LS1TECH Sponsor
If it's handling you are after, then I'd skip any panhard bar for a Watts link. As for the sway bars, I have both my hollow and UMI's solid's. I used to make solid and decided to drop them because for all the money folks spend on upgrading this and that to Chrome-Moly to save a couple of pounds I kind of thought it was nuts to add that much weight in a solid sway bar. But the UMI's are a few bucks less and well balanced, which is why I carry them as an option.
Those are the two things you really want to upgrade handling wise. Of course you need decent bushings and such, and there are any number of ways to do those via all new arms, or new parts in stock arms, or upgrading CERTAIN arms. All of which we could discuss if you want. Here's a hint: I'd do some arms, some bushings (and none with press in aftermarket urethane either like Energy or Prothane).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I was primarily going to to the a-arms because I need new ball joints. I've read it's a pain in the *** to get the bottoms out, especially without air tools. For what the shop would charge me to replace them, I could justify buying new a-arms.
What Strano said, plus when you goto 18" wheels, you can then run Michelin Pilot Super Sport tires, which I have found quite awesome on all fours, are a top rated Ultra High Performance Summer tire by Consumer Reports, and come with a tread wear warranty to boot! This was *the* reason I went to 18", since that tire did not come in the 17".
The OP said nothing yet about what tire is being considered and nobody asked -- that's another key to the handling equation...
