C6 Z06 Brake Upgrade Question
Old 07-02-2014, 04:03 PM
5_litre_eater's Avatar
Default C6 Z06 Brake Upgrade Question
I'm going to order the parts to do the C6 Z06 brake upgrade as soon as my new wheels get delivered and installed. I know Kore3 sells the kit for a reasonable price, but I was thinking about putting my own kit together because I don't really like their adapter bracket design.
My only question is what brake lines can I use? Will the factory camaro lines work? I have a full set of SS lines for the camaro, so I was hoping to use them. If not, I think I can still return them to Summit, and then I will just buy from Kore3..
Old 07-02-2014, 04:18 PM
Super Hulk Smash
JakeFusion's Avatar
You'll need new lines. They won't be long enough. I'd just get them from Kore... The UMI bracket looks nicer to me, so maybe you can order everything but the bracket from Kore?
Old 07-02-2014, 06:06 PM
That's exactly what I needed to know. I'll just order the lines from kore.
Old 07-04-2014, 11:14 AM
mikey4play's Avatar
I just did the C5 brakes on my 97. Got the caliper kit and hoses from Kore3 brackets from BMR and ebay rotors. Install was pretty easy.
Old 07-07-2014, 12:17 AM
ssjason232's Avatar
I have this setup on my 99. The Camaro lines ARE long enough.
The vette lines are like 8 inches longer and need to be managed ( believe me, I have them). Make sure that you use camaro or c5 lines, c6 ones have different body side threads and won't fit.
Use the GM rotors if you are on a budget. They are super cheap and hold up well.
Old 07-07-2014, 11:51 AM
Sounds good.. I might just stick with the SS lines I have now then.
One more question about the pads and rotors. I've decided my car will now be a fun street car, and wont be tracked (or might be tracked once or twice just for fun). I'm going to get the OEM Z06 Rotors and THINKING about getting the Hawk ceramic pads, mainly just to keep the wheels clean. Am I crazy? Or should I just get the HPS pads?
Old 07-07-2014, 07:19 PM
jrwilliams95z28's Avatar
i did the c5 z06 swap and the stock lines worked, they were alittle tight with the suspension fully extended and the wheel turned away from the line but with weight on the suspension they had slack.
Old 07-08-2014, 10:29 PM
Well it looks like Kore3 is out of stock on their brackets and C6 Z06 calipers. Does anyone know any place else that sells the calipers at a decent price? I didn't find anything that great on ebay...
Old 07-09-2014, 09:39 AM
TORK?'s Avatar
Have you thought about the 6 piston ctsv brakes as an alternative? No aftermarket bracket required, calipers are reasonably priced on amazon, and pads are cheaper.
Old 07-09-2014, 11:56 AM
I have thought about that, but I don't like the idea of using washers for spacers. Washer thicknesses vary so much, I would be worried about positioning the caliper incorrectly. That, and the fact I would have to paint the calipers red (since they dont come red). I suck at painting things.
I've also heard of people having a hard time getting ahold of the guy that sells the custom lines. (flybynite?)
Old 07-09-2014, 12:23 PM
Super Hulk Smash
JakeFusion's Avatar
Amazon usually sells the GM calipers cheaper than anywhere.
Old 07-09-2014, 03:51 PM
The must be out of stock all over. I'm having a hard time finding any for sale.
Old 07-09-2014, 03:58 PM
R Myers's Avatar
Core3 is the way to go on the bracket I have c6 zo6 brakes on my 98 Camaro and it was an ease install. I don't think UMI makes a c6 z06 caliper bracket. Check out my post on my upgrade.
Old 07-09-2014, 03:59 PM
R Myers's Avatar
Just got doing a track at VIR and the brakes worked great.
Old 07-09-2014, 04:04 PM
R Myers's Avatar
https://ls1tech.com/forums/suspensio...-1998-z28.html
Old 07-10-2014, 08:41 AM
brigade24's Avatar
good to know...i'm thinking of doing this as i also track my car...i'm hesitating because of the extra weight...the 14" rotor isn't light and if you factor in extra rotational mass...i wonder if it is significantly better than the base c6 setup using the 12.8" rotor.
then again, it looks so damn cool!!!
Old 07-10-2014, 09:14 AM
i think the c6 z06 brakes are totally excessive, between the extra weight of the bigger rims required and the weight of the rotors no thanks. ill stop just as fast with c5 z06 brakes.
Old 07-10-2014, 09:16 AM
I'll admit, I'm going mostly for looks. That's why I went with the C6 Z06 calipers I ordered from Kore3 last night. It will take about 3 weeks, but they were awesome to deal with.
Old 07-10-2014, 09:21 AM
oh if your going for looks then the c6 z06 cant be beat, except for maybe the new z28 with carbon ceramic rotors
Old 07-10-2014, 12:24 PM
yeah, I can't wait to get them installed. I think they are going to look bad *** with my new Z06 Spyder wheels!
Quick Reply: C6 Z06 Brake Upgrade Question
