LOL WTF!?!?! Front A- Arm Cotter Pin Bolts won't come off
So I was in the middle of removing my front driver's side A-Arm and took out the cotter pin and removed the nut. Now the bolt won't come off. I've removed all the other bolts but the 3 cotter pin bolts are giving me problems. Can't get any of the 3 out.
They make a tool specifically for this called a pickle fork. If you use the above mention method of hitting the top portion of the threaded part to free it loose you risk damaging the threads or mushrooming the head of the threaded shaft if the joints are stuck on there pretty good. It may work sometimes, but not always. Always good to have the correct tool.
I just leave the castle nut on the end of the stud so it is flush with the top, and then give the whole thing a good whack with a small 2-3 lb sledge. Works every time and very low risk of damaging the threads as the nut protects them. Also keeps things from flying apart or dropping since the nut is still on there.
Pickle forks can damage the boots on the ball joints and tie rod ends though. I just leave the castle nut on the end of the stud so it is flush with the top, and then give the whole thing a good whack with a small 2-3 lb sledge. Works every time and very low risk of damaging the threads as the nut protects them. Also keeps things from flying apart or dropping since the nut is still on there.
The key is to hit it flush center, I also use a smooth faced hammer so it will not leave any marks on the bolt/nut
If you hit it flush center it will pop out on the first try
Hitting it at a slight angle is when you damage it
