rear lca options
rear lca options
My car currently has a set of aftermarket lca's that were on it when i bought it and the bushings are shot so im looking at replacing them. I am looking into either getting a set of stock lca's and having the factory bushings replaced with new rubber bushings before i install them or i also have heard that bmr sells their lca's with the option to get rubber bushings which i may look into if it will be about the same price. Are there any other options out there for a daily driven car that at this point rarely sees the track?
LS1Tech Premium Sponsor
If there is any way we can help you out just let us know.
Here are a couple pictures of our BMR lower control arms with rubber bushings and poly bushings:
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Id go poly poly adjustable if it was me. Sure you can go fixed length but at some point you may end up needing the adjustment and have to buy again. My stockers bushings were fine so im not sure why yours were so messed up. I think I threw mine in the bushes in the wifes flower bed.
Any of our BMR lower control arms that have poly bushings can be had with rubber bushings. They are very quiet and are still a good improvement over the factory lower control arms. If you aren't set on rubber bushings, we also have the lower control arms with the poly bushings which are still pretty quite and offer better rear end control than the rubber bushings do.
For a street car, id stick with rubber ends. I had to call BMR to get their on car adjustable LCAs with rubber ends. If i could id get rid of all the poly bushings in my car.
For a street car I'd avoid poly. It resists the twist motions the LCAs go through too much IMO. I went Founders 3 piece poly as it seems to be a good happy medium as it is basically a type of spherical bushing but not noisy like a rod end can be. Plus, they cost me under $100 IIRC. Easier to do that than screw with pressing bushings into the stock arms.
If your looking for bind free suspension we offer Roto-Joints Fabricated at our UMI facility.Short for Rotational Joint the Roto-Joint allows 28 degrees of total rotation and unrestricted movement throughout the vehicles suspension. It is designed to work like a spherical rod end while maintaining streetable qualities of a softer bushing and designed to articulate and prevent suspension bind, and since the installed delrin race does not deflect like softer bushings, there is an improvement in traction and a significant reduction in wheel hop.The Roto-Joint is adjustable and 100% rebuildable. This means as the delrin race wears the adjuster ring can be tightened using the optional spanner wrench to apply tension to the ball. If the delrin race would ever wear completely it can be replaced easily.
If you need any info or pricing just let us know.
Craig
Craig
Yeah, we can definitely get you taken care of with rubber bushings. I will tell you that the whole deal with poly bushings binding in lower control arms really gets blown out of proportion. Really the only time you will even notice the bind is if you are planning on doing any kind of serious handling stuff otherwise it is really a non-issue. We sell more LCAs with poly bushings than any other design and very rarely get any complaints with them, when we do it is a noise complaint that is generally fixed by lubing them.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Craig
Craig
I have these on ALL ends of my rear LCAs and panhard bar.
I LOVE these things as they do exactly what Craig has described above.
I only WISH that they made some which could be installed in the stock/factory FRONT upper and lower control arms!
