Our ugly factory calipers.......question
Has anyone used JB Weld to fill in the dimples and casting spaces...and then successfully either painted or powder coat them?
Not sure if powder coat will stick to JB Weld. I see the temp is no problem for powder coat, if it will stick to it prior to the baking process.
Or will chrome plating stick to JB Weld...?
I was going to chrome plate everything (pics below)......or chrome plate the brackets and paint the calipers in red.
Regarding powdercoating over JB weld, PsychoSid and I have been fighting this issue. The problem we get is that JB weld tries to rise when in the curing process of powder coating. We've been trying to get a set of valve covers to cure just right after deleting some unused bungs for coil brackets, but it keeps leaving slight discoloration and minor bubbling.
We've tried JB Weld as well as the high temp JB Weld. He supposedly got some All Metal or something that is supposed to do well with powder coating, but it was so minor to me I just went with the JB Weld.
But yeah, I think the answer is just making CTS-V brakes work. There's no salvaging these stockers.
Maybe....??
Any problem with filling in the u-shape areas? I don't think it will stop from using a tool for a brake job or anything.
I would say its designed the way it is for a reason. What reason that it, i have no idea. But i would leave it the way it is and just get them powder coated....or get some CTS-V brakes like stated before. They look great, its a big brake upgrade, and they perform very nice.
Do you still need the bearings from the Vette up front?
Will it upset the balance between the front and rear brakes...?
Are they a bolt on upgrade...?
Caliper and rotor when received
after painting logo
Mounted on car
Installed with 18x10.5 wheels offset 50
The only problem you may have it wheel clearance, some have got away with 17" wheels but I had to go with 18"
yeah... idk cause these are the "hurst" brakes which are made by racebrake and I got the pair for just over $400...
each core from RB costs more than this whole set did, I don't know why these are so much cheaper.
They are ours! 120.65. Got the wheels and tires used on CL for $800
What I meant with the JB Weld was to kind of reshape the caliper by filling in the three casting spots on the front calipers and maybe even totally fill in the two U-shaped openings so you cannot see the back of the brake pads.
I had Sara's (2001 Z28) calipers and brackets painted with high heat flat black, and added high heat gloss yellow strips.
I had the casting lines shaved and the dimples welded up on my stockers before getting powdercoated. The decals were put under the clear. Also had the brackets podercoated as well.
