Braided lines on all 4 or just the front for CTS-V Upgrade
Old 04-26-2016, 09:49 AM
Monello's Avatar
Default Braided lines on all 4 or just the front for CTS-V Upgrade
Any advantage to doing the upgrade on all 4 corners?
Old 04-26-2016, 10:44 AM
Phoenix64's Avatar
The only advantage to braided lines is that they are less likely to break if hit by some debris, otherwise they are a waste of money.
Old 04-26-2016, 11:42 AM
Monello's Avatar
Got it. Someone was saying that the stock lines can balloon under high heat. No sure if its true or not.
Old 04-26-2016, 02:34 PM
TX98Z28's Avatar
I'd go with the braided so there all new at once. Stock lines are 15 years old or more, not saying yours are bad, only saying stuff wears out over time and not skimp on any part of the braking system.
If this helps my entire braking system will be new soon with the restoration, except for the actual metal lines and the ABS module.
Old 04-26-2016, 02:50 PM
ss4chad's Avatar
eBay pricing on name brand parts!
http://www.ebay.com/itm/131466078170?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Chad
Old 04-26-2016, 03:20 PM
Monello's Avatar
Nice find chad! So these will work with the CTS-V 4 piston calipers and stock rears?
Old 04-26-2016, 07:59 PM
TX98Z28's Avatar
I'm pretty sure you need the conversion brake lines from Kore 3 to run those calipers on front.
Old 04-30-2016, 09:34 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Thumbs up
This statement is very true, the braided line kit from Russell is rated @ 300psi, and the kit has upgraded banjo fittings to boot. These lines will not leak or balloon, and because of this it gives you a stiffer brake pedal.
That is a good price for the kit, I paid $89 (14 years ago) for the 5 line kit, for Sara (2001 Z28) does not have traction control.
Old 05-09-2016, 08:40 PM
lsx55's Avatar
Lol @ the internet
Teflon Stainless Steel braided lines won't expand under pressure, period.
Quick Reply: Braided lines on all 4 or just the front for CTS-V Upgrade
