Need help just bought some adj.strange shocks
Just recently bought a set of used front shocks. They are adjustible coil overs made by strange. I only have the bottom seating with the washers and bearing.it didnt come with a top seating. My question is there supposed to be a top seating as well? Could i use the one off my stock shocks. Or does the spring just rest under there and compress when u lower the car down. Any help is much appreciated. Never delt with coil overs
LS1Tech Premium Sponsor
the problem you are going to have is the diameter of the spring. If you are trying to use the stock or stock-style springs, you will need an adapter to go from the 2.5" coilover seat to the stock size spring. We offer these just for this purpose, they can be found here: http://bmrsuspension.com/index.cfm?p...294&superpro=0
Alternatively, if you want to use a coilover style spring you can either purchase the upper hat to use a standard flat end 2.5" spring, or Qa1 offers springs that are flat at the bottom and use the stock upper mount seat. They can be found here: http://bmrsuspension.com/index.cfm?p...708&superpro=0
let me know if you have any other questions
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Have 2 picture here one is where the coil spring rest in thr stock upper mount and the other has a small hat cover ontop of thr spring.. do i need to run that small hat spring or can i just mount my shock with the coil on thr factory upper isolator like pictured. Never had coil overs before. Bought my shocks used. So not sure what parts im missing
The picture on the left is using Hypercoil springs using the stock upper position like shown, the other is using a 2.5 coil over spring that has everything to mount it in place.
Your easiest and most likely cheapest bet would to order these.
http://midwestchassis.com/products/s...prings-spc300a
Sold individually and have them in stock.
Those are Hypercoil springs designed to use the stock upper seat. You should be good to go. Viking springs are Silver and have a flat top like these:
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Cool appreciate the help. When i bought these shocks the springs were in viking boxes and he said thet were viking springs so figured they were viking. Then i wasnt sure if i needed that little hat that set on the top of the coil.. but anyways appreciate the help
No problem, any other questions feel free to ask.
