Corvette brakes on F-body
If you are looking for calipers only, they bolt right in. If you're looking for the bigger rotors, you will need some sort of bracket to relocate the caliper. UMI, LG, and if you can find a set Bob Bishop, makes the relocation bracket. Depending on all the options you choose, it could run from $250-$800.
So all I need are cross drilled / slotted rotors for my T/A ( stock size ) and I can put corvette calipers on there with no problem ?
Front and rear ?
Front and rear ?
Front and rear ?
Front and rear ?
For rotors I would say pass on the cross drilled/slotted and go with something else, this is my opinion. There is some different options out there depending on your driving style. Trackbird a member of this site would be able to tell you the best choice.
Good Luck
http://www.umiperformance.com/c5conv.aspx
Ryan
Copy & Paste Moderator
Just a few threads I found.....
**https://ls1tech.com/forums/showthrea...corvette+brake
BTW, there are many more threads on this subject.
Restricted User
This is what I made for my cars.
I started with Bobs bracket.
http://photobucket.com/albums/y190/7...t=100_0026.jpg
