Lowering, What Stuff Should I Change With it?
Old 02-20-2006, 01:20 AM
killerbeez's Avatar
Default Lowering, What Stuff Should I Change With it?
Hey, I couldn't get a really good search on this topic. But, considering I'm going to pay a shop to change out my front springs, is there anything else I should get besides struts so I don't wish there's something I'd of wish they changed while the front end was apart? Like just LCA's?
Old 02-20-2006, 03:43 PM
Strokinit383's Avatar
Depending on the mileage of your car, Id check the balljoints. I think the lowers are only like 16 bucks, so worth taking a look at. The uppers are a little more expensive, but I'd take a gander.
Old 02-20-2006, 06:43 PM
LoudmouthLT1's Avatar
Shocks and adjustable panhard bar, you will be needing these things.
Old 02-20-2006, 06:44 PM
StealthFormula's Avatar
Panhard so that your rearend is centered after lowering.
Old 02-20-2006, 09:02 PM
227Hawk's Avatar
Shocks!
Hawk
Old 02-20-2006, 10:01 PM
OneMeanZ's Avatar
Originally Posted by 227Hawk
Shocks!
Old 02-20-2006, 10:21 PM
Black_Bird's Avatar
shocks definitly... adj. panhard bar... LCA relocation brackets, I dont get it though, are you just changing the fronts?
Old 02-21-2006, 12:18 AM
killerbeez's Avatar
No I'm not just changing the fronts, but the fronts are a pain in the *** so I don't want to have to go back and redo something on 'em later. If I can't afford EVERYTHING now, I'd rather do just the front stuff for now, since the rear stuff will be a lot easier to add later.
So :
F/R - I need shocks
F - LCA (are these just on the front is it on all 4 corners)
R - Panhand bar
Right?
Old 02-21-2006, 01:39 AM
Screamin_Z's Avatar
lower control arms are on the rear, they are the lil bars just inboard/front of ur wheels. they attach from the car to the rear end. u really don't need to replace those BUT u do need LCA relocation brackets, those put the LCA's back into geometry.
springs, shocks, adj panhard bar, LCA relo brackets and depending on how many miles are on ur car upper/lower ball joints. take a look at ur rubber "pieces" for the suspension...if they look worn either buy OEM or poly to replace them.
if u don't get an adjustable panhard bar u might as well keep ur stock one on there. U NEED AN ADJ PANHARD AND LCA RELO BRACKETS TO PUT THE REAR END BACK INTO GEOMETRY.
u do not have to get new shocks but it's HIGHLY recomended. I put new DeCarbons on my car with Hotchkis springs...bad idea. it rides hard. So I'm gonna invest into Koni's but if u cannot afford those then some KYB AGX's or Bilstein revalved would do good.
Old 02-21-2006, 07:42 AM
227Hawk's Avatar
Here's some quality UMI parts
Hawk
Quick Reply: Lowering, What Stuff Should I Change With it?
