Stuck bolt during suspension install
Old 03-23-2006, 08:43 PM
Powered By V8's Avatar
Angry Stuck bolt during suspension install
Well after about 3hrs of trying to install my new koni sa's I didnt get to put the drivers side in .
The bolt that was stuck was one of those stupid T-50 torx bolts that are located under the hood by the master cylinder. The damn thing would NOT budge...even on the air gun. I broke 3 T-50's trying to get the f*cking thing out, and almost stripped the star pattern. I had it soaking in liquid wrench for a while too.
Any suggestions guys? I had to put the whole assembly back together too because I had to drive home, which pisses me off
edit: Also, can I replace those rediculous torx bolts with regular ones? Or is there some unseen reason for using them?
Old 03-23-2006, 08:54 PM
Krab's Avatar
Don't know what else you can try to get it off, but I'm pretty sure they can be replaced by regular bolts as long as they're the same length.
Old 03-23-2006, 08:57 PM
227Hawk's Avatar
You can change to regular bolt head. I did on my initial install. That way i can get a wrench on the bolt-head. And don't have to pull the master cylinder when i drop my upper 'A' arms
Hawk
Old 03-23-2006, 09:04 PM
Should I just grind the head of the bolt off? I didn't want to go that drastic
Old 03-23-2006, 09:58 PM
mitchntx's Avatar
When I went back together with my set up, I used the hex bolts from the passenger side under the MC. Easier that the Torx heads to get to.
I then put the Torx head over on the passenger side because I could get a wrench on them easier.
If the bolt is siezed, it's seized for a reason. You should replace the upper perch as it obviously has a problem.
Old 03-24-2006, 06:50 AM
227Hawk's Avatar
That was my way of putting it back together.
Great minds.........................
Hawk
Old 03-24-2006, 09:30 AM
Upper perch...is that the upper control are that sits on top of the spring? Can I get a part number for that?
Old 03-24-2006, 09:32 AM
mitchntx's Avatar
Probably ... from a dealership.
I, on the other hand, bought a set of Monroes from O'Reilly's ...
Old 03-24-2006, 09:36 AM
OneMeanZ's Avatar
How much did those run you if you don't mind me asking?
Old 03-24-2006, 09:59 AM
I generally try to stay away from the dealership when it comes to purchasing parts because of the massive ***-raping my wallet gets when I buy stuff from them.
Monroes..? Any link or info on those?
Thanks
Old 03-24-2006, 10:57 AM
6 spd LT1's Avatar
I bought monroes from advanced auto too. i bought the fronts for about $60 a piece and the rears for about $15 a piece.
anthony
Old 03-24-2006, 02:49 PM
daryl2cb@yahoo.com's Avatar
damn that sucks, have you tried loading the suspension, might take some stress off the bolt.
Old 03-24-2006, 03:51 PM
Well, I had a jack underneath the lower arm so it was under a decent amount of pressure. But I'll give it a try when I get a chance.
Anyone ever heard of wacking the head of the bolt with a hammer to break it loose? That's wat my dad suggested.
