UMI LCA's poly/poly noisy!
Old 07-18-2006, 06:43 PM
jlashley2001ss's Avatar
Default UMI LCA's poly/poly noisy!
I think i may get rid of my UMI LCA's. A little noisy for my DD. Anybody had a set of UMI's that were noisy? What brand should i get that isnt noisy?
Old 07-18-2006, 07:01 PM
Copy & Paste Moderator
VIP1's Avatar
What kind of noisy? If they are squeaky, grease them with a good synthetic grease. I use Mobil 1 red synthetic grease on the poly ends of my Spohn rod/poly LCAs.
Old 07-18-2006, 07:54 PM
i had them greased this weekend...still got some noise.
Old 07-18-2006, 08:32 PM
UMI Performance's Avatar
What type of noise are getting from them?
We have never had a complaint on a poly/poly set-up like that. Maybe we can get it to go away.
Thanks,
Ryan
Old 07-18-2006, 08:46 PM
well here is what i got http://byunspeed.com/product_info.ph...509da2bab31c96 it makes a lil chatter noise. I just had the ends greased and everything.
Old 07-19-2006, 12:30 AM
jmilz28's Avatar
What kind of noise is it?
What kind of shocks do you have?
Is everything tightened to spec?
You need to look into those first, and actually check on the third one.
Old 07-19-2006, 06:41 AM
Viper's Avatar
I've asked him to do the same in this other post he has about it:
https://ls1tech.com/forums/suspension-brakes/543707-noises-after-panhard-bar-lca-install.html
Quick Reply: UMI LCA's poly/poly noisy!
