noises after panhard bar and LCA install?
well i installed UMI panhard bar and LCA's and now im getting some weird noises in the back? I put some grease on the ends and still getting weird noises. Its not BAD but enough to hear every now and then and knowing its not suppose to be like that(I dont think)? What is this??
Torque specs on the LCA's is 80ft/lbs on the nut and bolt; check both ends to make sure you are that tight. On the PHR, it's 61 ft/lbs. Also on the PHR, on the passenger side, the bolt should go in from the inside, with the nut visible on the outside when looking at the car from the rear. The driver's side is reversed; you should see the bolt head when looking from behind and the nut should be on the inside.
Not 100% sure, but the holes are 'tapered'. If you look at the bolt itself, it's thicker on one end than another.
What ends are on the pieces? Like poly, rubber, rod-ends? If it'a a poly/rod-end combo, did you install the poly on the body and the rod-end on the axle? 90% chance it's the LCA's making the noise, the PHR rarely makes noise.
I've gotten a lot of different noises since the install of my PHB & LCA's. It's to the point right now that I've bought a 2nd set of lca's with poly on both ends. I'm hoping this is going to clear up the thunking noise that I've in the rear
what brand you going with? I thought UMI PB and LCA's were poly on both ends?
I've got the same problem, i have rod end LCAs and PHB, i'm about to change to poly and see if that gets rid of my noise. The rod end ones are strong, but a little too noisy for street use IMO.
this is the set i bought http://byunspeed.com/product_info.ph...0db4e2ac7c16c6 I had them greased up and still have noise As stated they are poly end bushings. Whats up with the noise?
when i had UMI's, it was only the LCA's i was using a stock PHB, so for me, it was the LCA's making noise. And i greased them and tightened the living hell out of them and it made no change whatsoever.
Originally Posted by jlashley2001ss
so you think its most likely the UMI LCA's? anybody else had issues with UMI's LCA?
Originally Posted by 98 Raptor TA
Dont mean to bash a brand but i think maybe those UMI's just suck. I had a set on my old TA and they made nosie, so i sold them and got BMR's and the noise went away.
Originally Posted by jmilz28
If you don't mean to, then don't. Their products are top notch and every issue I've ever heard of with them (and it's not many) was installer error or another problem that throwing that particular part at would never fix. You don't seem to have given Ryan a chance to help with your problem. His customer service is tops as well. Bash away...
And yes we get very minimal to no complaints regarding this issue. For manufacturing and selling hundreds of sets this is really the first time I have seen this. The first issue is rod ends, the majority of you are running either rod end/rod end or poly/rod end. Although we use high quality rod ends lets face it, you are replacing a 2" think rubber bushing with a solid joint that has no deflection. Now with that being said we have very minimal issues to none, we run these everyday and I am pleased with the results. If you are replacing your rod/poly set-up from us with brand X using poly bushings on both ends then that is the exact reason they are quieter, its not the brand that fixes the problem its the set-up. If you want that correct performance from your vehicle then some sacrafices must me made, rod ends being one of them. If you do not want any noise issues then you may need to stick with a item that will work but just not be best fit for your application.
Regards,
Ryan
