Bad rack?
Bad rack?
My steering wheel shakes back and forth at just about any mph over 30. Tie rods are good as are the wheels and tires. There is no play in the steering, but the only thing I can think is that the rack is bad. Anything else that could cause this problem?
check the steering fluid level, if it seems low, then fill it and keep an eye on it. Check under the vehicle for any obvious leaks... if it is going bad, metal flakes can get in the lines and ruin the pump.... if I'm not mistaken
