Brake Pad Help!!!!
Old 07-10-2007, 04:58 PM
DanPazich's Avatar
Default Brake Pad Help!!!!
Bought new Hawk HPS pads, and got the frontgdrivers side on ok. Trying for the front passenger side and i have the pistons pushed in as far as they go and the caliper doesnt fit over the rotor....probably by a 1/16". If i bang on it hard enough, it will probably eventually slip on.. .
Any help?? should new pads fit that tightly against the rotor that it doesnt spin at all?? Any help is appreciated!!
Old 07-10-2007, 08:29 PM
Copy & Paste Moderator
VIP1's Avatar
Inspect the sliding pins to make sure they haven't seized and re-grease them with a good high temp grease while you are there.
Old 07-10-2008, 11:28 AM
1996z28's Avatar
Sorry for bumping an old thread but I have a similar problem and have not been able to figure it out.
Old 07-10-2008, 12:55 PM
VIP1's Avatar
Did you do what I suggested above?
Old 07-11-2008, 10:04 AM
1996z28's Avatar
pm sent.
Old 07-11-2008, 11:19 AM
VIP1's Avatar
I haven't had to deal with stuck sliding pin yet. They should move smoothly in/out to allow for pad wear (since the calipers only have pistons on one side).
Here is the closest I could find in threads:
https://ls1tech.com/forums/suspension-brakes/489258-caliper-bracket-issues.html
https://ls1tech.com/forums/suspension-brakes/327595-brake-help-needed.html
