Leaky reservoir?
Leaky reservoir?
Anyone else's brake fluid reservoir leak a little fluid?
My car has 24k on it, and it seems like every month or two, the top part of the reservoir is wet like a bit of brake fluid leaked out from under the cap.
Do I need a new cap or what?
thanks
thanks
That's debatable. They are both vented caps due to the fluid levels raising and falling so they aren't supposed to leak, but they do. It's only a drop or 2 a day. If it's leaking around the seal, then replace the seal and see if that fixes it. If it's still leaking a tiny amount then it's probably just the normal amount. I see F-bodies all the time in the dealership and they all have that build up of dirt around the caps. The only ones that are semi-clean are the guys who keep their engine bays clean. With the boots on there, mine always stay clean. After 6 months or so they will be dirty, so I toss them and cut out 2 more. Simple.
Copy & Paste Moderator
I though you meant that you replaced the lids with towels.
That's why I was confused.
