Whats stock ride height
Wondering what the stock ride height is for a 2000 camaro Z28 I bought the car lowered and I it is sitting really low thinking maybe the springs are sagging. so before I go buy spring I would like to know if itll lift or lower my car anymore.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by 2000Z28ls1
mmhh I wonder where they measured from think the floor below the door to the top of the t tops?
I was wondering how much off the ground it sits cause my car seems really low so anywith with an unlowered camaro wanna take a some measureing tape for me and measure from the bottom of the driver front wheel to the middle of the driver front fender?
How much of a drop are you looking for?
The Eibachs are notorious for lowering more than advertised, but I am not familiar with the other brand you mentioned.
Strano springs lower 1.25", and Hotchkis and BMR both lower 1". I have the Hotchkis and I am pleased with them- the drop is just about perfect, and with Strano revalved Bilsteins the ride quality is pretty good for a lowered car, IMO.
Good luck whatever you decide! Let us know how it works out for you.
LS1TECH Sponsor
Most LS1 cars are about 27" front, 28" rear ground to highest point on the fender openings *with* stock diameter tires.
I don't know what you have, but my springs result in a height that's pretty consistantly 26" front, 26.75" rear on stock diameter tires.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Copy & Paste Moderator
Suspension Mods in sig.
:::::::::: Fender :::::: Inside ::::: Fender :::::
:::::::::::: To ::::: Wheel Well ::::: To ::::::::
:::::::::: Ground ::::: To Tire :::::: Tire :::::::
**DRIVER**
FRONT::: 26.75" :::::: 4.25" ::::::: 1.75" ::::::
REAR::::: 27.75" :::::: 6.25" ::::::: 2.75" ::::::
**PASSENGER**
FRONT::: 26.75" :::::: 4.00" ::::::: 1.75" ::::::
REAR::::: 26.75" :::::: 5.25" ::::::: 1.75" ::::::
Interesting that only my driver's side rear is 1" higher.
(Probably for the theory that it'll level out with a driver.)
Some people on here that have measured their stock ride height have come up with higher numbers than mine (about 1/2" - 1" more). I have the stock springs. I've had the car since new. I can't explain why my car is lower.
I think my ride height is low enough. I don't want my car any lower than it is now.
No I havnt gotten around to it I misplaced my tape measurer and Ive been really busy with work and stuff. Also my car is acting up again so I gotta find the problem thinking maybe a coil pack so I gotta pull them off and test each one.
