Pinion angle with stock torque arm
Old 10-29-2007, 04:12 AM
Jimmard's Avatar
Default Pinion angle with stock torque arm
Does anyone know, or has anyone measured the pinion angle on a stock car with the stock torque arm? I'd measure it myself but I got rid of my stock torque arm, nothing came up on the search, so I figured someone might know. Also, how much would the pinion angle change when the car is lowered say an inch or inch and a half? Thanks
Old 10-29-2007, 11:52 AM
OldeSkool's Avatar
i was under the impression that stock was 0* but never bothered to measure. apparently it needs to be slightly less than that for proper u-joint operation.
i will get a measurement for you this weekend if no one else beats me to it.
With a full-length torque arm you're not going to see a significant change in pinion angle when you lower the car. the full length t/a maintains the same pinion angle through most of the suspensions range of movement.
Old 10-30-2007, 03:38 PM
Jimmard's Avatar
So it's just 0* then? Can anyone confirm that? Thanks for the help
Old 10-31-2007, 12:53 AM
OldeSkool's Avatar
i'm told that exact 0 is bad for the u-joints. so it's probably just a hair or two negative.
i'll get you an exact measurement this weekend
Old 11-04-2007, 09:19 PM
OldeSkool's Avatar
Im sorry bud, I can't find my angle finder (and i've got at least 2 ) anywhere. If it doesn't turn up I'll go pick one up, but it may be a while.
Quick Reply: Pinion angle with stock torque arm
