HELP: people in houston area that know suspension VERY WELL.
Old 01-16-2008, 01:22 PM
TX_Stang4lunch's Avatar
Default HELP: people in houston area that know suspension VERY WELL.
i need someone i can take my car to, to get my car right. I dont have alot of time on my hands and i dont know wtf i am doing when it comes to suspension. So i need a trustworthy EXPERIANCED individual to help me make the right decisions that will get my car to where id like it to be.
ive posted about changing my setup, and while ive gotten great feedback....its still not something im comfortable or have the time and tools necessary to do myself
please post up if u know whats up
Old 01-16-2008, 02:45 PM
LS1Tech Sponsor
MADMAN's Avatar
Call Josh or Steven at Late Model Racecraft http://www.latemodelracecraft.com/
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-16-2008, 03:12 PM
robertbartsch's Avatar
Swapping suspension parts is not rocket science. The tricky part is matching the components to get the result you are seeking.
Sam Strano is an excellent source who could talk you through the process --->
You might order the parts from him and get a local guy to install them if you are a dunce at mechanical work.
Old 01-16-2008, 04:34 PM
well i dont have a factory setup..... thats what is throwing me off ... big time
and i think that the weld in mods that were done before my time are all wrong (wolfe racing sway bar setup) . Thats the prob. Anyone can change out struts / shocks/ lca / ect. but when it comes to taking a torch to your rearend and problem solving id wrather leave that to some one who knows WTF is up ......
Old 01-17-2008, 09:35 PM
Manic Mechanic's Avatar
What part of Houston? Anyone recommended will have to be a LS1Tech sponser or it can and will be deleted and the poster dealt with. LOL
Vernon
Old 01-18-2008, 04:26 AM
Why would a sway bar be welded to the car (frame, rear-end)?
Old 01-18-2008, 09:34 AM
z28bryan's Avatar
Before you start looking for mods, identify what you want to do with the car. Setting up for drag racing can be counterproductive if you want to road race and handle well around turns.
In my case, I'm pretty much all road race/autox setup. Though I have a need to launch well on a crappier surface on mild drag radials (555r's). So I'm looking into what I can do other than improving the driver that will give me a little more of an edge in launching.
Old 01-18-2008, 09:56 AM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
You need to contact these guys. If you are that lost they wil get you going in the right direction.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 01-19-2008, 09:53 AM
looking to go with more of a road course type setup. and the guy that had it before me was going more drag setup.
Called LMR and talked to steven, i think this is what were going to do:
let me know if theres anything you would change
BMR Lowering Kit (1"in drop)
BMR Front Sway Bar(with bushings) 32mm - 1993-2002 F-Body
BMR Rear Swar Bar(with bushings) 21mm - 1982-2002 F-Body
BMR Full Length Adjustable Torque 1982-2002 F-body
BMR Torque Arm Relocation Kit
LSX Comp Cam
Install Lowering Springs
Install front and rear sway bars 2
Install Torque Arm and relocation kit 2.5
Install Cam Shaft
Custom Dyno Tune
i will probably add some koni's in there but the $$$ is getting tight with all the other stuff.
I allready have bilstein revalved shocks ( slp level 1 suspension)
Old 01-19-2008, 10:18 AM
chupr0kabra's Avatar
I personally didn't like the 32/21 swaybar setup. The bigger rear bar felt like it made the car understeer. I went back to a 32/19 setup and am much happier.
Just my $0.02.
-Mike
