Where do I get the kit to eliminate ABS?
Old 01-25-2008, 06:53 PM
no title here
skyhighsami's Avatar
Default Where do I get the kit to eliminate ABS?
I was told the other night that I can buy a kit that will elimnate everything that has to do with the ABS and save me some weight. Where do I get it and do any ABS lights appear ( I am sure they do) and if so how do you delete them? Thanks
Old 01-25-2008, 07:07 PM
billybadd's Avatar
SJM has a kit.
Old 01-25-2008, 07:51 PM
no title here
Is it worth it?
Old 01-25-2008, 09:00 PM
warp10's Avatar
Some lights will turn on and there are no other choices then either removed the LED's from the unit or use the black tape method.
You can either go and buy some tubing, flare tool and adapters and do it yourself or you can get some delete kit form SJM. Your choice.
Old 01-25-2008, 10:36 PM
no title here
How hard is it to remove the cluster and unplug the lights?
Old 01-26-2008, 10:53 AM
SJM Manufacturing Inc's Avatar
It takes about an hour to get to the instrument panel. You essentially need one wrench/socket to remove the screws.
Some can ground out a few of the lamp feeds to shut off the lights without even going into your dash with years 93-98.
Regarding is the kit worth it? You could try to build one yourself...modifying your own car is sometimes self-gratifying. Just about every item you see on the boards here a person could make. Regarding our kits, if you were to purchase all the pieces yourself, the lines, adjustable wilwood valve, all the fittings etc etc...most would find it is not worth the time. The idea of a kit or any manufactures component available is to offer a solution for the end user.
Old 01-26-2008, 11:17 AM
LS1TECH Sponsor
Steve Burger's Avatar
We have a delete kit and it is on sale for 5% off right now. Let me know if we can help.
Old 01-26-2008, 12:54 PM
I've had this asked before...For clarification and comparison to the above kit our kit differs quite a bit:
Our kits:
1) Our kit ompletely removes ABS modulator AND bracket, we do not use a block which only connects lines together.
a) This eliminates as much mass as posible.
b) Creates better air flow for engine bay.
c) Gives user more room for supercharger/turbo configurations.
2) Ours includes proportioning valve in every kit.
a) Without a valve, you have no brake bias adjustment. Your ABS used to control this. When you remove ABS, you have about as much likelyhood of being hit by lightening that your brake front/rear bias is balanced.
3) Our kits comes with preformed lines and fittings needed for install.
4) Our kit enables user to remove existing braided lines.
a) braided lines left in a system will expand to a greater degree vs. hard lines. Expansion in lines lead to lower braking reaction.
5) Our basic kits start at 139.99. This includes all preformed lines with nesessary flared ends, proportioning valve and all fittings needed. For 40.00 more, you'll receive a biondo style line lock solenoid with electrical kit. The electrical kit consits of wire, master switch, control switch, remote LED, electrical connectors...even down to the firewall grommet. Add 20.00 more if you do not have a double flare tool.
Old 01-27-2008, 07:34 PM
no title here
I was thinking this morning about it and I think I am going to get the kit you described there SJM with the Line Lock because with a M6 car it would make getting heat in the tires alot easier. I will let you know as soon as I am ready to order it.
Old 01-28-2008, 04:45 PM
LS1Tech Premium Sponsor
BMR Suspension's Avatar
SJM (in my opinion) offers the best complete kit out there bar none.
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 02-03-2008, 04:56 PM
95GreenZ28's Avatar
Hey Steve!!! I am wanting one of these kits for a lt1 car. Have any deals going on them right now? Thanks man! Sorry to interrupt the thread guys.
Josh
Old 02-03-2008, 05:03 PM
For the LT1 cars here's the link: http://www.sjmmanufacturing.com/cam_brk_lt1.html
Old 02-04-2008, 08:45 AM
95GreenZ28's Avatar
Any way you could do a free shipping special?
Old 02-04-2008, 09:38 AM
zlover129's Avatar
any pics of it installed? just curious since i've done this on a couple cars and was wondering how they compare. And you're correct, for those who want to save money its not too hard to purchase seperate and do yourself
