Must Have Suspension Mods
I have a 02 Formula and I am looking to improve the handling. I already have purchased KYB AGX shocks. For $500 what are the must have suspension mods?
I went with strano springs and sway bars...but that will be around $800. Probably the best money I have spent on the car, besides my Corsa catback. But the sway bars can be done later.....so really, your best bet is going to be springs and an on-car adjustable panhard bar, which will center the rear end after you lower the car. Don't waste your money on strut tower bars and I wouldn't get too hung up on a torque arm just yet either, that will mostly help in straight line hard acceleration.
You could always grab a set of UMI poly/rod adjustable LCA's & on car poly/rod adjustable panhard bar. You want poly rod for a couple reasons.
1) the poly bushing connects to the body & will help dampen noise
2) the rod end connects to the rear & allow the rear to articulate over uneven surfaces opposed to a stiff poly bushing.
Torque arm, and now I would say K-member after seening UMI's after market one in person.
Start by getting rid of the K's you need Bilsteins or Koni's only IMO. Difference in price, but leaps and bounds in performance.
Get Sam Strano's springs. These are the springs our cars should have come from the factory with. Ride quality, height and responsiveness are perfect. Best money spent. Then save for the sway bars, if you can only do one then get the front. I don't know about the KYB shocks, so can't offer input there. The Koni's are nice, that's what I have.
Chris
Chris
