Good info on Fbody suspension facts
Old 05-14-2008, 10:01 AM
Redlinez's Avatar
Default Good info on Fbody suspension facts
As far as I'm concerned, this is good info that I agree with. I've never bought LCA's because I was never sold on the benefit they would give me. Of course, I'm sure there will be arguing different opinions, but I believe this to be factual, which I know is hard to believe exists in the automotive world, much less performance automotive. There's a need for "upgraded" suspension components I'm sure, just not for everyone.
http://www.geocities.com/acarnut99/bushings.htm
Old 05-14-2008, 10:16 AM
vikingramair's Avatar
Ouch! let the battle begin!
In the red corner ....and in the blue corner....
Old 05-14-2008, 10:21 AM
BIG_MIKE2005's Avatar
I generally don't believe much of what I read off the internet about stuff like this. If I have suspension questions I talk to the man, Sam Strano.
Old 05-14-2008, 10:30 AM
z28bryan's Avatar
That's a good read. Gives a lot of reasons why things occur the way they do. They didn't really explain why using the lower point on the axle of a relocation bracket causes high speed turning instability though. It can cause the rear axle to toe out slightly away from the direction you turn when the car is rotated to the outside.
Old 05-14-2008, 10:31 AM
z28bryan's Avatar
As far as what I've heard from Sam, this link is pretty consistent with what Sam has mentioned in the past.
Old 05-14-2008, 12:24 PM
99Bluz28's Avatar
Alot of good info there.
Old 05-14-2008, 03:13 PM
turbowhistle86's Avatar
wow....kinda makes me want to take my new BMR LCA's off.
Old 05-14-2008, 04:32 PM
Redlinez's Avatar
Don't forget my last sentence.
fortmyerspolice's Avatar
glad I didn't use my money on LCA's just yet.
Old 05-14-2008, 05:21 PM
DanWS6's Avatar
Yeah.
Old 05-14-2008, 06:00 PM
leadfoot4's Avatar
As long as you understand simple geomery, you can then see why the suspension needs to "flex" somewhere, as the rear axle pivots in an arc defined by the panhard bar. That flex point, as the "postie" indicates, is either the LCA bushings, the mounting points on the rearsubframe, or the mounting brackets on the axle.....Take your pick.
Personally, I'd use spherical bearings on the LCAs, IF and only IF, I lived where the roads were a LOT smoother than where I live now.
Old 05-14-2008, 10:57 PM
Nabdrill's Avatar
I had to go with tubular LCA's to make a tiny bit more space to run the BS on the weld wheel with 325/50 MT DR. The stockers rubbed.
Old 05-14-2008, 11:21 PM
Sunset'01Z's Avatar
they cured alot of wheel hop in my car.. it could have been the bushings, idk, but i'm glad i got them.
Old 05-15-2008, 12:20 PM
00 Trans Ram's Avatar
Rubber . . . poly . . . goose gizzards . . . pelican *** . . . who cares? Just get spherical bearings (rod ends) and be done with it.
Old 05-15-2008, 12:36 PM
Easy for you to say, I don't want my car to sound like a mattress when I go over a speed bump
Old 05-15-2008, 03:21 PM
Viper's Avatar
After having bmr poly/poly, lg arms with poly/rod, rod/rod LCA's, I'm now back to 1LE LCA's and the car handles great AND the noise factor is great.
Old 05-15-2008, 03:34 PM
Where can we buy 1le bushings other than gmpartsdirect?
Old 05-15-2008, 03:50 PM
Viper's Avatar
Sam Strano sells them. www.stranoparts.com
You need to call him to order them, they are not on the website.
Old 05-15-2008, 04:15 PM
Yeah, I know - I was kinda being sarcastic. It's really hard having to make compromises.
Old 05-15-2008, 04:33 PM
Redlinez's Avatar
I just got mine in today and installed them. Moog part number I listed, about $21 each, you need quantity two. The whole 1LE control arm is about $108 each.
Quick Reply: Good info on Fbody suspension facts
