do i need more suspension work pics inside
Old 06-07-2008, 04:31 PM
droptopT/A's Avatar
Default do i need more suspension work pics inside
ok guys when i went to the track last time i felt the car twist alitle in the lauch i already have bmr subframe connectors and relocation brackets comp engineer drag shocks set at 50/50 and no frontt sway bar in the pic above u can see it lifted alitle bit from the left tire but my 60's went slower my best 60 foot was a 1.630 and now its lauching like that it only goes 1.723 what do i need i also have a stb is that helps any.my buddy was telling me to look into drag bags do i really need this or would a beefier rear sway bar help
Old 06-07-2008, 05:28 PM
Killer_Z's Avatar
what shocks u runnin? control arms? springs? looks like ur pushin some good power to lift up like that,
Old 06-07-2008, 05:52 PM
droptopT/A's Avatar
um i on;y made 361 rwhp 348 torque and i got the comp engineer drag shocks stock springs no front sway bar m/t et streets bmr sfc
Old 06-07-2008, 06:19 PM
87formy's Avatar
What are you running for a rear sway bar? I'd look into a bigger one or an anti roll bar.
Old 06-07-2008, 07:39 PM
z28bryan's Avatar
There's a guy here who showed before and after pictures after putting in a large rear drag swaybar. He basically made what you currently have, launch straight.
Old 06-08-2008, 04:22 AM
droptopT/A's Avatar
i have the stock rear sway bar
Old 06-08-2008, 09:55 AM
kenSS's Avatar
i would def. consider the spohn or bmr rear drag bar. i'm saving my pennies right now for one.
Old 06-08-2008, 03:53 PM
droptopT/A's Avatar
i was thinking about the spohn drag bar but how hard is it to adjust
Old 06-08-2008, 04:02 PM
1_bad_TA's Avatar
Drag bags and even a bigger bolt in sway bar will help.
Old 06-09-2008, 02:24 AM
droptopT/A's Avatar
i think drag bags would be cheaper than a sway bar but what psi to run in the bags or do i only run one bag in the right rear
Old 06-09-2008, 02:28 AM
1_bad_TA's Avatar
Put bags in both sides. Play with the pressure and see what works the best. Shop around and you will find a sway bar for a good price. I'm getting a Suspension Techniques 1" solid sway bar for $110.
Old 06-09-2008, 04:10 AM
droptopT/A's Avatar
thanks i really apreciated
Old 06-10-2008, 05:55 PM
ODAWG's Avatar
Good info I needed that myself!
