Traction
Traction
I have been having issues with traction and am looking for some advise. I have a full weight 2000 SS (3580 lbs with driver). I'll spare all the mods and move on to the suspension and tires. I run 26x10.50-16 MT ET Streets. I have a Spohn Adj. Tunnel Mount Torque arm, Double adj. LCA, LCA relocation brackets. I run stock 3.23 gears in the stock 10 bolt. The panhard is stock and so is the sway bar. I have Eibach Pro Kit with stock shocks and struts.
I have tried from 20# air pressure in the tires down to 15#. I adjusted the LCA as short as possible to get more weight behind the tires and set pinion angle to -2. My best 60' has been a 1.54 on a 125 shot, anything bigger than that and I spin. The best that the car has done is a 10.97 with a wheel hopping 1.57 60'. I'd like to get my 60' into the 1.4x with adjustments.
Give me some ideas and input, please.
battery relocate and get some stiff rear shocks. Maybe drop some wieght off the nose and the rear tires wont have to fight to get the cars total inertia going, not to mention overall handling will improve in the proccess.
