Brake Pads Dragging
Brake Pads Dragging
What is the number one cause of front pads dragging on rotors (stock brakes)? Wheel takes two hands to turn when up in the air.
Both front's are dragging bad. I can push in the pistons and wheel spins like a bike tire, but after pumping pedal, it goes back to dragging. ABS inop light and Brake light was on about week ago but hasn't come on since.
Any help on diagnosing or info on what are the most popular causes is appreciated.
I imagine it's either:
MC piston stuck
Caliper pistons stuck
Bad Fluid
Collapsed rubber lines
ABS Issue
MC piston stuck
Bad Fluid
ABS Issue
The first thing i would check is the caliper slides. They are very common to rust. I know from personal experience. It could also be a caliper issue. I wouldn't think that it would be ABS or MC.
