ABS relocate
Old 08-31-2008, 07:32 PM
JerikSS's Avatar
Default ABS relocate
How can I relocate my ABS Box? I need to move it out of the way. How do I go around doing this? I dont know abs, or if I need to get lines extended, where to get them? stuff like that. Can anyone help
Old 08-31-2008, 08:26 PM
Restricted User
socmguy's Avatar
You can delete the whole thing all together with an SJM ABS delete kit!
Old 08-31-2008, 08:46 PM
JerikSS's Avatar
I would but I like the added safety of the abs. Plus when it times come to sell, most people want it on there.
Old 08-31-2008, 10:04 PM
2002_Z28_Six_Speed's Avatar
Does the kit require everything you would need or do you need to shop for additional parts beforehard??
I have been wanting to do this for awhile.
Old 08-31-2008, 10:35 PM
kyles2000z's Avatar
im interested in seeing if theres anyway to retain ABS but have it hidden from view as well!!!
Old 09-01-2008, 12:29 AM
Restricted User
socmguy's Avatar
The kit comes with everything, **** you can even buy a flaring tool from them.
Check out SJM on the right------------>
Old 09-01-2008, 10:54 AM
JerikSS's Avatar
I would love that too.
Old 09-01-2008, 06:43 PM
Yea, I am checking that out right now. It looks like their kits even come with some factory type fittings.
I just want to order a high quality kit that will stand up to DD use and include everything I need.
Old 09-01-2008, 09:48 PM
JerikSS's Avatar
HELP!
Old 09-01-2008, 11:08 PM
SJM Manufacturing Inc's Avatar
Originally Posted by JerikSS
HELP!
There is no room to move the modulator and bracket which being practical in any way shape or form. You could always remove ABS as described from other fellow members using our kits.
If you sell the car, keep the old parts and re-install them. You're not damaging the ABS unit by remove it...so it can be re-used. All of the lines leading from the master cylinder to the modulator are removed as well, our lines replace them...so those would be a no-brainer to re-install.
Good luck!
Old 09-02-2008, 12:01 AM
mitchntx's Avatar
I've seen a couple race cars (C5s and Mustangs) that have relocated the ABS into the cab.
Adapt to -3AN from the MC and route braided line to the ABS module which is adapted from -3AN to metric. Edlemen makes a wide line of adaptors.
Then run new lines to the front brakes and then the to the rear diff.
It's not hard nor expensive ... just takes a little research.
Just remember to keep all the brake lines below the MC reservoir to reduce the liklihood of trapping an air bubble.
Old 09-02-2008, 09:00 AM
dragonrage's Avatar
Also the lines as they go towards the MC should stay horizontal or go upwards, not back down.
Quick Reply: ABS relocate
