Car sits to low
Old 09-17-2008, 03:12 AM
smokinponcho73's Avatar
Default Car sits to low
I bought the car with qa1's up front and need to raise it up to help with the 408, I was told what I need is lt1 springs what are you all thinking Thanks Brandon
Old 09-17-2008, 09:12 AM
BMR Tech's Avatar
Are you using the QA1 type springs on the front now or stock style springs?
Old 09-17-2008, 02:37 PM
I think they are stock springs with qa1 coil overs
Old 09-17-2008, 02:46 PM
99Bluz28's Avatar
Question
Why don't you just adjust the spring seat up higher.
However much you want to raise the front up, just move the threaded spring seat up 1/2 that amount.
Old 09-18-2008, 01:37 AM
do i need to buy the shim kit when i buy a spanner wrench or can i just get the dual spanner wrench and be fine?
Old 09-18-2008, 09:09 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
The thrust washer kit helps the spring turn easier. You don't have to have it but it does make it easier. If you need the thrust washer and spanner kit i have them or if you just need the spanner wrench we've have that too.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-18-2008, 04:15 PM
sorry for me asking but what is the dual spanner wrench for, I heard that you need two of them and saw summit has the dual for fairly cheap.
Old 09-18-2008, 05:29 PM
99Bluz28's Avatar
Thumbs up
Their used to adjust you ride height.
Yeah, thats all you need;One to hold the spring seat still, and the other to loosen/tighten the lower collar(jam nut).
FYI,
Spray some WD40, or dry lube on the threads right above the spring seats before trying to loosen them, and be prepared to lose some skin on your Knuckles in the process.
Old 09-18-2008, 05:49 PM
thanks blu, Hey dennis how much do you sell the dual's for? You can pm me if need be
Thanks Brandon
Old 09-18-2008, 06:02 PM
99Bluz28's Avatar
Lightbulb
Thanks Brandon
BMRs spanner wrench is $15 ea.,I just checked.
Quick Reply: Car sits to low
