sway bars worth it??
so im debating on getting the bmr 35/22 set up because the price is good. does it really matter if i get them or just save my money? im just hitting the track once in a while and just DD it. i got tq arm,sfc,lcas,phb & relocation brackets should i get something else or would this help me out? thanks
Well i was gonna say you should go with Strano's sway bar set because they are hollow compared to BMR's which are solid. But I just checked Strano's site and i think they doubled in price since i bought them. So yea, i'd say go with the BMR's. My Strano bars made a very nice improvement. theyre hollow which is stiffer, but those should also perform well.
I finally installed my strano front bar after letting it sit for 4 months! OMG - HEUGE difference - the Konis can't even compare to this change... but the Konis may work with the bar so who knows
LS1Tech Premium Sponsor
http://www.bmrfabrication.com/F4.htm
LS1TECH Sponsor
Just back at work... I'm behind since I was closed for almost two weeks while I was in Kansas (winning my 5th National Championship). I'll make this short and sweet.
I did my hollow bars they way I did because I felt that was the best combination of size, weight, cost and performance. If you want to save some money, we can do you solid bars in the same sizes (but few opt for these since you are gaining about 20 pounds of weight). Are there other opinions on what "works"? Sure. But I'm not one-trick pony. You want a 32mm bar? A solid 22 rear? A 25mm rear? I have all of those too.
FWIW, the stock GM front bars are all hollow....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
