What C5 Adapters are these?
Old 09-28-2008, 07:12 PM
wht01ws6ta's Avatar
Default What C5 Adapters are these?
I bought these C5 adapters from a member thinking they were UMI since they look similiar but after looking at more pics of the UMI adapters I see these pieces I have are different. Anybody know who makes these and also, bonus question: which adapter goes on which side of the vehicle?
Pics of the adapters put together which shows the bolt holes are all in the same place.
Old 09-29-2008, 10:01 AM
UMI Performance's Avatar
Our brackets are machined from a solid block of aluminum and those are fabricated from steel.. so you are correct they are defiantly not ours.
I am not sure what brand those are to be honest.
Old 09-29-2008, 10:21 AM
wht01ws6ta's Avatar
Thanks Ryan. I'm sure yours are lighter and maybe even stronger with the extra brace and being machined from a solid block.
Yeah I have no idea who made them either. Anyone know?
Old 09-29-2008, 10:25 AM
firebird6786's Avatar
they look like KORE3 brackets that were painted black
Old 09-29-2008, 10:27 AM
I don't think KORE uses steel that thick... I think there brackets are only 3/16" thick.
Old 09-29-2008, 10:35 AM
Xsta Z 28's Avatar
They look close to the original "Bob Bishop" brackets?
My pics here: http://www.netsnapshot.com/pcw/b?KEY=6&ACCOUNT=4394
Old 09-29-2008, 03:36 PM
wht01ws6ta's Avatar
They do look like those brackets from what little of them you can see in the pics. Xsta Z 28, is that your tutorial?
KORE3 brackets look a lot different in this picture: http://www.kore3.com/proddetail.php?prod=10105-01
I had to grind down either the nut on the spindle or grind down the adapters to get them to fit correctly so the adapters aren't perfect as far as their dimensions go.
So, which one goes on the drivers side? On the top pic, it's the one on the left, correct, because that's the way I put them on
Thanks for the help!
Old 09-29-2008, 03:58 PM
Xsta Z 28's Avatar
Yes those are the pictures I took while doing the install on my 2000 SS.
I did not have that issue . . .
From your pics and my pics, I assume the one on the left in you picture . . . but if they are on and working I guess you got it correct!
Old 09-29-2008, 07:14 PM
wht01ws6ta's Avatar
Well the hole spacing is identical on both adapters so they actually will bolt up to either side fine but I figured the beefier portion of the bracket should be at the top because the force of the forward rotating rotor (and the force of the forward moving vehicle behind the rotor) would put lots of pressure on the top part of the adapter. So I hope I got it right...
Old 09-29-2008, 10:09 PM
02TransAm/Batmobile's Avatar
Pretty sure they are made by engineered velocity.
Old 09-30-2008, 09:52 AM
wht01ws6ta's Avatar
Thank-you! I looked at their website and those look like the exact thing. I also searched and saw found a few older posts about their adapters: apparantly not bad quality just a little heavier because of thick steel and cheaper than most.
Old 10-01-2008, 12:48 AM
No problem, I went with engineered velocity's brackets. The dude was super nice as hell and always returned my emails quickly.
Old 10-01-2008, 01:56 AM
darknessxyz's Avatar
X2. I'll buy from him. Cheaper and reply email fast. Maybe I'd have a machine shop weld the "Middle brace" if you feel like. The only thing is, he charge $25 for the mounting hardware on the "bay".
Old 10-02-2008, 09:14 AM
wht01ws6ta's Avatar
Yes, Joe is very helpful and prompt with the email responses.
For anyone else that has these or is buying them, he said that the side of the adapter with the extra metal goes to the bottom of the bracket so that is the opposite of what I have them mounted. This isn't explained in the intruction document and you can't see it in the pictures in there either. But they fit the same both ways since the bolt holes are in the same place. I had swapped them to see if they fit any differently. The extra metal is just there for extra strength but these things are thick and seem to be strong as hell anyway.
