QA1 springs questions
Old 10-01-2008, 03:09 PM
Big Bird WS6's Avatar
Default QA1 springs questions
are they bad for a daily driver car? i know there are alot of choices out there. just wondering wht people thought of them on the every day street?
thanks
Old 10-02-2008, 09:52 AM
any one?
Old 10-02-2008, 10:49 AM
BMR Tech's Avatar
Which spring rate do you have ?
Old 10-02-2008, 02:34 PM
lee,
don't have them yet. want to know how street able they are. i want one that is street able. yet does it's job at the track
Old 10-02-2008, 03:38 PM
BMR Tech's Avatar
The rate I recommend most of the time are the 300# units. The only time I would recommend the 315 is if it's an iron block car or a turbo car with the extra weight on the nose.
Old 10-02-2008, 04:10 PM
mattl31's Avatar
remember, you can also re-use your stock springs if you use BMR's spring cups. they are 60 bucks and will allow you to run conventional diameter springs (including stock and aftermarket lowering springs) while saving you about 60 bucks. just got mine put on with stock springs, BMR cups, and single adj QA1's. rides great, handles good for a drag shock. give BMR a call, its a quality piece.
Old 10-03-2008, 11:09 AM
BMR Tech's Avatar
Very true!! almost forgot about this option
Old 10-03-2008, 11:55 AM
lee,
what about the back? what spring rate for that?
and this car sees more street then track.
thanks
Old 10-03-2008, 12:41 PM
z28bryan's Avatar
Don't they all go by 275, 300, and 325 or something like that. If you ask me, I'm sure all 3 are pretty streetable. Were not talking about 400-600 here which is also very much streetable given good shock dampening.
Old 10-03-2008, 01:33 PM
what is thie 275,300, 325 comparible to ?
like what is eibach rated at?
sam'ssprings?
BMR springs?
Stock?
anyone know this?
Old 10-03-2008, 02:03 PM
z28bryan's Avatar
As far as fronts go, Stock are 292, Sam's are 550 linear, and BMR's are 310 to 550 progressive. I'm not sure what rate the car actually sits at loaded though for the BMR's.
Note that the higher rate complements the lower ride heights for Stranos and BMR springs. Well designed springs are built at their rates and ride heights for a reason.
Old 10-03-2008, 03:21 PM
BMR Tech's Avatar
Originally Posted by Big Bird WS6
lee,
thanks
The factory rear V-8 springs work well with the "Hose Mod" to help with height.
